![]() | Home > Maintenance & Mods (L322) > Fitting a DPF sensor to my L322 4.4tdv8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
What difference has it made? |
kenneally_mark Member Since: 09 Jun 2021 Location: Cork Posts: 74 ![]() ![]() ![]() |
It's driving much smoother & quicker. None of the hesitation that was there previously |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Which sensor was it that you replaced? Location etc? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The DPF sensor. It's near the passenger footwell underneath. |
AdrianL322 Member Since: 06 Sep 2022 Location: Ås Posts: 15 ![]() ![]() ![]() |
Do you know the correct LR part number for the DPF pressure sensor? I see both LR122713 and LR023134 are listed on this site: parts.jaguarlandroverclassic.com I read somewhere that there is a difference between "AA" and "AB" sensor type aswell? Also do you have the part number for the two clips you mention? I have the same fault codes and are concidering to change the sensor. 2012 Range Rover TDV8 4.4 |
