Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 17 of 35 <123 ... 161718 ... 333435>
MarianaWestminster
Well that's what I did do in my message Haylands but now I think about it I don't see how it could work as I wouldn't be able to leave the car with them.
Re think needed.
Been a family function tonight and my cousin has bought a 2017 RRS.
and you guessed it... Nice light steering.
Sigh Banging Head
Post #665593 31st May 2023 9:52pm
MarianaWestminster
Thinking out the box again here...
When I had my main battery tested (by a good friend, whom I trust) as my start stop wasn't working not only did he find the cause of that (bad cell in the main battery) but he also did a charging system test and I've just remembered he told me that his tester was showing a fault with the charging system.
Now I haven't had a flat battery and I can see the voltage rises up when running to charge the battery but could this be something to look at?
Could it be a bad ground or something affecting the systems?
I know these have a common issue with the ground in the drivers side wheelarch but that's normally accompanied by a load of fault messages on the dash which I've never experienced.
I do sometimes get a random error beep on startup but never any accompanying message to tell me what's faulting.
Post #665670 1st Jun 2023 8:20pm
MarianaWestminster
Cleaned up the drivers and passenger side ground points today (behind the front arch liners)
Little bit of corrosion but not too bad. I was lucky in that mine came undone just fine and didn't snap off like others.
All cleaned and refitted then covered in grease (good preventative maintainance I suppose)
I've also had the fuse (fuse 55 in the boot, for the adaptive damping) out over night in an attempt to reset any 'adaptions' in the module.
Went out at 11am and first difference, it didn't crash over the ridge at the top of my close.
Today the engine has been responsive, the steering light and the suspension had some suppleness to it.
First day I've enjoyed driving the car since the week I bought it.
Even stopped in a field for picnic on my lonesome.
No doubt it'll be back to being cr*p tomorrow but we live in hope...
Post #665980 5th Jun 2023 9:04pm
Here's hoping.... Thumbs Up Pete
Post #665982 5th Jun 2023 10:05pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
fingers crossed for you, ive been following this thread but not contributed as I have nothing to add of any use, First time FFRR owner
Post #665983 5th Jun 2023 10:06pm
caymanblack
Fingers crossed Thumbs Up overfinch modified
Post #665984 5th Jun 2023 10:07pm
Merchy
Fingers crossed, been following this thread, I sincerely hope it goes well Sir Thumbs Up
Post #665989 6th Jun 2023 1:18am
MarianaWestminster
Thanks guys, I have a very rare week off work this week but need to travel to see a supplier today so we will see how it goes.
Oh and an update on my damaged mirror cover, I managed to find one in the correct colour on ebay which was removed from a new car for just £25! So that's all sorted now and you'd never know Thumbs Up
Post #665996 6th Jun 2023 7:22am
MarianaWestminster
Well as expected it didn't last... back to business as usual today.
I give up.
Post #666032 6th Jun 2023 5:02pm
MarianaWestminster
Any other thoughts from anyone that don't involve me spending money just to be told they can't fault it?
It's at a point now where I'll take any excuse not to drive this car.
It's not pleasurable in any way, hard to steer, laggy engine with thumpy gear changes and a ride stiffer than an M sport BMW on run flats.
I've just wasted nearly £500 on an iiD tool to see if I could recalibrate the adaptive damping but that option is seemingly unavailable on L405. Banging Head
Post #666296 9th Jun 2023 11:04pm
GraemeS
Use the tool to check the outputs from the 3 CVD accelerometers if this hasn't already been done. Initially check the values whilst stationary and while travelling slowly on a smooth surface in a straight line when they should all be about the same and not jumping about.
Post #666297 10th Jun 2023 5:09am
MarianaWestminster
Yes I've done that Graeme and they aren't jumping about or 'swinging' the values don't change until I drive.
I need to figure out how the 3 complaints are connected and why the 3 cars have all been the same/very similar.
Late 2009 L322
2011 L322
And this 2016 L405.
I know this can't be right as my early 2009 L322 was NOT like this at all.
Post #666301 10th Jun 2023 7:35am
GraemeS
Your recent cleaning of earth points sounded hopeful as a poor earth somewhere could affect many systems, but obviously not those earth points.
Was the ambient temperature and time of day on the good day after cleaning the earth points similar to those of the following day when the symptoms returned?
I'm soon to try to remotely assist the owner of a 12-month old Defender that has an unusually harsh ride compared with a neighbour's identical vehicle. A big difference between his vehicle and yours is that when a shock's electrical connector is unplugged the ride doesn't seem to get any worse. 2 LR dealers can't find anything wrong so he has just purchased an IIDtool that hopefully will help indentify the cause. The LR dealers didn't monitor any live values, only running self-diagnostics on the chassis module and a seat of pants comparision with another vehicle, albeit on the smooth surburbian roads unlike the rougher roads where he lives.
Post #666317 10th Jun 2023 12:47pm
MarianaWestminster
Yes I thought the same about the earth points Graeme.
And yes similar temperature and both driven in the morning both days.
My ride does get significantly worse when unplugging a shock connector and inducing an adaptive dynamics fault.
There has to be something connecting the 3 systems I complain about to end up having a laggy feeling engine, stiffer than expected steering and a harsh ride. But what is it?
Thought I'd made progress yesterday as I used the IID to reset gearbox adaptions, engine adaptions and throttle adaptions which seemed to cure the engine lag for 6 or so drive cycles but the laggy feeling returned on the 7th cycle or so.
Having had 3 RRs that behave like this and one that didn't does point the finger at me but the fact that sometimes it is 'ok' is what stops me accepting I'm the fault.
Post #666318 10th Jun 2023 12:57pm
knwatkins
I remember some time ago watching some Sam's Motor and Machine videos on YouTube. He had some long running issues with a hard ride on his L322. It could be worth reaching out to him if he ever managed to resolve the problem. I believe he tried quite a few avenues for resolution. He's also on here, but I don't know his username.
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #666344 11th Jun 2023 8:42am
