Home > Maintenance & Mods (L322) > Rear wheel arch protection second thoughts
DrRob
I’ve been a long advocate of protecting the leading edge of the rear wheel arches with Freelander 2 trims but after 2 years I removed mine and surface rust has appeared.
Quickly resolved with some Neutra Rust 661 as per Sam’s Motor and Machine YouTube video on the same subject.
Before.
After
Also removed wheel arch liner and very little rust behind. All waxoyled and will remove every 2 years or so
So, I won’t be replacing the Freelander 2 trims in leading edge Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #665833 3rd Jun 2023 8:22pm
DrRob
Also, a comment from the video on RRO YouTube channel that Matt Stevenson did on the subject
My mind is made up. Keep it uncovered and clean it regularly etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #665834 3rd Jun 2023 8:26pm
amazing stuff that Neutra Rust 661
makes sense to keep air flow around the problem area Rob.. Thumbs Up ... - .- -.
Post #665835 3rd Jun 2023 8:35pm
DrRob
Sam’s video for reference 👍
😎 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #665837 3rd Jun 2023 8:42pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Good idea to discuss, yes I found the same on my L322 having fitted the edge protection and have now removed them. I intend to pull the rear arch liners every couple of years and address any new rust spots, I did that last winter and found some light surface corrosion on a previously treated area so rubbed it all back and epoxy primered the susceptible areas before top coating with chassis black and then a liberal coating of grease.
fanders Thumbs Up ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #665855 4th Jun 2023 7:40am
DrRob
Any thoughts from the collective minds on what's the best protection for that metal arch area?
I've rubbed down and treated with NeutraRust661 and now deciding what to do next.
Epoxy paint has been suggested on the Book of Faces Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #665927 5th Jun 2023 7:25am
fanders
I've gone:
- Abrade back to bare metal
- Rust treatment stuff (can't recall the brand but the stuff which goes on milky-white and dries blue/black
- Epoxy primer
- Chassis black
- Buckingham blue topcoat rattle can/clear coat on visible areas (although I left the outside edge of the wheel arch lip flange in chassis black as it will get battered by stones and is in a 'dark hole' area anyway)
fanders ---------------------------------------
2021 Hilux 2.4
Post #665931 5th Jun 2023 8:06am
DrRob
Bring that epoxy primer to the Pots on Thursday fanders Whistle Wink Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #665949 5th Jun 2023 12:02pm
DrRob
Plan is to
1) Paint over the Neutrarust661 treated arch lip with epoxy primer then
2) Metal paint then
3) thin layer of Hammerite underseal
4) Monitor and react as appropriate Rolling with laughter
No costs as I’ve got all this in stock 😂
Post #666037 6th Jun 2023 5:33pm
DrRob
Rest of arches in very good condition. Couple of spots treated then old skool clear waxoyl as it’s in stock here 👍
Post #666038 6th Jun 2023 5:35pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
A timely post - I was just about to fit the Freelander 2 protectors that have been sitting in the garage for 2 years! Kurust and Hammerite (old stock, full strength) is now the plan, served me well on the TVR chassis over the years. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #666101 7th Jun 2023 11:55am
mjdronfield
The LR protectors aren’t too bad, think I’ve had 3 sets, but they corrode eventually too as there is a metal strip along them to add rigidity. I think the rust there then makes the arch worse when it starts, so you have to whip them off in time.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #666102 7th Jun 2023 12:32pm
DrRob
Sounds plausible. I'm going the naked route now Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #666103 7th Jun 2023 12:34pm
DrRob
eBay them Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #666104 7th Jun 2023 12:37pm
DrRob
I thought you'd had it Lanoguarded at Glenrands aswell? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #666105 7th Jun 2023 12:37pm
