Home > Maintenance & Mods (L322) > Rear wheel arch protection second thoughts
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
stan wrote:
amazing stuff that Neutra Rust 661
makes sense to keep air flow around the problem area Rob.. Thumbs Up
Is it basically the same as Hammerite Kurust? Ah, I see it's twice the price, so assume it has some added goodness. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #666121 7th Jun 2023 5:39pm
RR2B
DrRob wrote:
RR2B wrote:
A timely post - I was just about to fit the Freelander 2 protectors that have been sitting in the garage for 2 years! Kurust and Hammerite (old stock, full strength) is now the plan, served me well on the TVR chassis over the years.
I thought you'd had it Lanoguarded at Glenrands aswell?
Yes, but they didn't do the wheel arch edges. In any case, I think they need some more robust protection. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #666122 7th Jun 2023 5:41pm
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Seems inevitable with these later cars, the rot will be in the sill as well.
Another job on my never ending list Sad
Post #666290 9th Jun 2023 7:57pm
DrRob
No sill rot. Full of waxoyl from 2020 work 😂 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #666291 9th Jun 2023 7:58pm
JamboM3
Ah didn't see it was you Rob Smile
Post #666292 9th Jun 2023 8:02pm
DrRob
So.
Neutrarust 661
Epoxy primer. Love it. Flexible stuff
Satin metal paint
Hammerite Waxoyl Underbody Seal
Monitor
😎 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667245 21st Jun 2023 5:11pm
DrRob
Waxoyl will dry to a matt finish….
Will report back in a few weeks 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667246 21st Jun 2023 5:13pm
JamboM3
Looks great Rob!
Post #667248 21st Jun 2023 5:23pm
DrRob
Even better with door shut and at night Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667249 21st Jun 2023 5:24pm
pcourtney
I've now also taken the Freelander arch protectors off and yes folks - rust is forming
So now following DrRob's 4 step plan over the Easter break Smile
1) apply NeutraRust 661 first 5L = £116 (more than I need, but have other cars to do)
2) then spray SOLL 400ml Black Epoxy Primer = £20 ( I bought 2 cans at £10 quid each )
3) then paint the arch with some Satin black matt that I already have in the garage
4) then Hammerite Waxoyl Underbody Seal 1L £15 (more than I need, but ..... )
Post #689382 29th Mar 2024 10:19pm
Rudyard1
When I had my rear arches replaced I asked the body shop to spray stone chip on that edge of the arch and it has remained perfect. I would advise people do the same! I’m guessing you could take your car in to any body shop and request they do just that for minimal cost. 2007 Range Rover Vogue 3.6 TDV8
Post #689390 30th Mar 2024 7:35am
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Have any of you tried Bilt Hamber products?
I have had great results using them and por 15 for rust
https://bilthamber.com/
https://por15.com/ Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689397 30th Mar 2024 8:57am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Big believer in built hamber stuff , use it all the time on customers cars and when I got my RR 8 years ago just about every bit of plastic was taken off under the car and it was coated with dynax or dynax underbody in the more exposed areas , sills and every bit of box section I could find was coated too inc bonnet and doors , 3 days in the air on the ramp but I'm hoping to have a nice motor for another 10+ years , strip it all down and check reapply as required year this year though .
Post #689941 4th Apr 2024 8:00pm
woodyrvf750
I’ve been faffing around with my rear arch liners this evening and am pretty sure that the front leading edge of the liner was designed to be fitted in front of, not behind, the leading edge of the wing.
If you look close enough there’s clearly a moulded lip in the liner that fits over the wing. The problem is, in my view, that this was too bloody hard to fit properly on the production line so they were all just banged behind the leading edge lip and sent on their way.
Anyone have a view?
Post #705445 25th Nov 2024 10:25pm
RobsterPC
It's early days for me and the Freelander guards but I made sure they were full of Lanoguard grease as well as greasing the arches themselves too. My view was that preventing water getting in contact with the metal as well as trying to ensure there's no gap for water and crud to get into was the way to go. Replacing the guards after a couple of years is much cheaper than patching the panels too.
Post #705496 26th Nov 2024 5:46pm
