Home > Technical (L322) > Battery drain - 2011 5.0SC - new AGM battery
AJT FF
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
I've been seeing the low battery warning recently and installed a new battery as the old one was 10yrs old. From what I saw the new battery fitted by Halfords was not coded to the car.
Now I am still seeing the warnings, just a day after after a 240m round trip. I have a clamp meter on order to check the drain and have read thru the boards but most of the discussions are around older L322 with headlight wipers. Mine does not have them.
Are there any likely candidates for a fuse check? I sat in the car today, locked the car and waited. There was a fan noise for about a min or two, then it stopped. It briefly kicked off for 10-15 secs after a couple more minutes but didn't come to life again for the next few mins.
Any pointers would be great.
Thanks
Post #665325 28th May 2023 7:23pm
You don't "have" to code the battery in but it will take a while for the car to learn it has a new one, you could try charging the new battery overnight... Thumbs Up Pete
Post #665338 28th May 2023 10:39pm
AJT FF
Thanks. I’ve had it on a trickle charger and it’s now showing full.
Still no idea where the leak could be!
Post #665350 29th May 2023 8:03am
JayGee
Could also be a failing alternator. 2012 TDV8 Vogue (L322)
Post #665351 29th May 2023 8:20am
garyRR
Usual culprits if not are a failing alternator as JayGee suggests, or the final stage resistor "hedgehog". 2015 Range Rover Autobiography 4.4 SDV8
Post #665361 29th May 2023 9:43am
AJT FF
Hi. just to follow up, I used my icarsoft diag box to run a voltage check with the engine on. I only saw between 11.8 and 12.2v rather than the 14.5ish I’ve been led to believe to expect. Would this point to a failing alternator? Thanks.
Post #665648 1st Jun 2023 5:44pm
JayGee
With a smart charging system the alternator doesn’t put out full voltage all the time. Try switching on every electrical load and see if it goes up. 2012 TDV8 Vogue (L322)
Post #665658 1st Jun 2023 6:39pm
