![]() | Home > Maintenance & Mods (L322) > Bonnet is open ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
as you look at the engine the alarm is very top left corner...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Or bend the metal bracket up a bit so the plunger is closer to the bonnet, or put a rubber grommet on the end of the plunger so it’s longer. I did both. No issues since…
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
"Or bend the metal bracket up a bit so the plunger is closer to the bonnet, "
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
When I bought my last FullFat it was probably 6 months before I noticed that the switch button had been taped in the down position. I found out why when I removed the tape..
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
hi all could you just disconnect it without having any problems new vehicle purchase
Suppose you could, but then your bonnet would not be covered by the alarm. The bracket isn’t massively thick and can easily be eased up a bit. That said, if the switch is broken you can disconnect it if you want.
