Home > Maintenance & Mods (L322) > Bonnet is open ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35466 |
as you look at the engine the alarm is very top left corner...
15th May 2023 4:27pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
Or bend the metal bracket up a bit so the plunger is closer to the bonnet, or put a rubber grommet on the end of the plunger so it’s longer. I did both. No issues since…
15th May 2023 5:43pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
"Or bend the metal bracket up a bit so the plunger is closer to the bonnet, "
21st May 2023 6:07am |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
When I bought my last FullFat it was probably 6 months before I noticed that the switch button had been taped in the down position. I found out why when I removed the tape..
21st May 2023 7:05am |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi all could you just disconnect it without having any problems new vehicle purchase
21st May 2023 7:18pm |
Suppose you could, but then your bonnet would not be covered by the alarm. The bracket isn’t massively thick and can easily be eased up a bit. That said, if the switch is broken you can disconnect it if you want.
21st May 2023 7:56pm |
