![]() | Home > Technical (L322) > 4.4 TDV8 Cracked air intake manifold |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Unfortunately a lot of my early pictures were deleted, but most come from the workshop manual.
The green arrow is pointing to the oilway connection that suffers the O ring leak problem. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Thanks Mike. I found this one on your gallery but thanks for re-posting. |
Can it be repaired by pinning it back together along the seam with some self tapping screws similar to what has been done to my plenum?
I've got a spare that I've cleaned and I'm going to reinforce the seams in the same way before I put it on. 2012 TDV8 Vogue (L322) |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Evening all, an old thread i know.
upagreen1 Member Since: 21 Feb 2021 Location: Yorkshire Posts: 9 ![]() ![]() ![]() |
this thread describes removal of the plenum: https://www.fullfatrr.com/forum/topic62108.html
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
James
Excellent, thank you both. Cheers
DannyJeff Member Since: 13 May 2023 Location: Brighouse Posts: 3 ![]() ![]() ![]() |
Hi James
