Home > Technical (L322) > New Suspension Issue/s
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
I've been having issues with lowering from extended height to normal pretty much since I got this RR last year; it states in extended mode and refuses to go down (just the front, or so it seems) but after repeated selection of the down toggle it will come down without further complaints. I'm assuming this will be a clogged pressure release valve filter. New filters on order.
A new issue has just recently 'raised' its head, or should that be 'lowered'... Rolling Eyes
When leaving the car for a short period of time, the front of the car will be very low. OSF being the lower of the two. So I plugged in my diagnostics (snapon) and forced the suspension to extended mode and as it rose, an air whooshing noise got louder as it got higher, slowing its ascent as it got louder and basically failing to get to full extension. Sounds like an air leak coming from OSF.
Fault codes stored were C1a13 - that'll be the blocked filter and C1130 - that'll be the OSF air spring with a leak in it. Damnit.
Went to http://www.Aerosus.co.uk and bought a pair of front air springs for £189 delivered! I am somewhat shocked by how cheap this was. Shocked Cam
2011 TDV8 Vogue in Stornoway Grey
Post #661777 13th Apr 2023 4:53pm
telly-addict
Got the OSF strut off and it didn't take long to find the problem. The split is normally hidden by the fold of the bag and explains how the suspension would work 'OK' until left, where it would slowly lower.
The strut is easy enough to strip down. A bit trickier to reassemble due to the new seals and relative stiffness of the new air spring. I discovered a potential problem when it was stripped, there was some minor marks on the part of the shock body that forms the air-tight seal. They looked like clamp or vice indentations and I was concerned about potentially damaging the new air seals, so I was able to remove the burrs with just some brown scotchbrite pad, then polishing compound.
With the strut reassembled with the new air spring and fitted back in the RR, the suspension now performs as it should. I even left it on offroad high setting overnight and no hint of having lowered at all in the morning Thumbs Up Cam
Post #662816 25th Apr 2023 8:50pm
mjdronfield
Sorted then. Not sure too many have tried the cheaper air springs. Hopefully prove reliable in the long term.
I drilled the filter years ago. No issues since.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #662817 25th Apr 2023 9:00pm
telly-addict
They look identical to the originals to be fair. Cam
Post #662898 27th Apr 2023 2:23am
