I've been having issues with lowering from extended height to normal pretty much since I got this RR last year; it states in extended mode and refuses to go down (just the front, or so it seems) but after repeated selection of the down toggle it will come down without further complaints. I'm assuming this will be a clogged pressure release valve filter. New filters on order.
A new issue has just recently 'raised' its head, or should that be 'lowered'...
When leaving the car for a short period of time, the front of the car will be very low. OSF being the lower of the two. So I plugged in my diagnostics (snapon) and forced the suspension to extended mode and as it rose, an air whooshing noise got louder as it got higher, slowing its ascent as it got louder and basically failing to get to full extension. Sounds like an air leak coming from OSF.
Fault codes stored were C1a13 - that'll be the blocked filter and C1130 - that'll be the OSF air spring with a leak in it. Damnit.
Went to http://www.Aerosus.co.uk and bought a pair of front air springs for £189 delivered! I am somewhat shocked by how cheap this was. Cam
2011 TDV8 Vogue in Stornoway Grey
