Do the starter relay mod as per FFRR14 in the first thread. I had almost identical symptoms. I fitted a new battery, a new starter motor and a new alternator chasing this but still had low voltage and starting issues. Thing is, the BMS is actually quite clever and, even though you’ll see low 12V as soon as you unlock the car as so many ECUs and lights etc, it will still start the car with lower voltage that you would reasonable expect.
However, the inability to start is almost certainly due to the single pathetically thin cable that goes from the fuse box in the engine bay, and works it’s way about 5m around the engine, dropping in gauge about half way along its length, to the starter motor. It’s the trigger wire that closes the relay in the starter motor solenoid that allows the high current feed direct from the battery to spin the motor. It’s simply not up to the job of holding the solenoid closed if conditions are not optimal and age/corrosion just create extra resistance down the wire exacerbating the problem.
If you want a ‘try before you buy’ solution, just run a suitable wire in parallel between the starter trigger wire in the fuse box and the starter solenoid. I’ll put money on that working and you having no problems starting as low as even 11.5V once done. If that does work, then I can’t recommend any more strongly to do the full relay mod as FFRR14 describes as an almost bomb-proof solution. I also did this mod about a year ago and, since I did, the car has never failed to start. Not once. In all weathers, and in all battery conditions. In the grand scheme of things I’m glad I did replace the starter motor and alternator as I’ll now hopefully have many tens of thousands more reliable miles out of those parts, as the originals had done 100k. However, for the sake of about £20 in parts and a few hours to do a meticulous job, the additional relay is probably the single best mod I’ve done to the car.
Good luck whatever you choose! 👍 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
