Home > Technical (L322) > Eas pump running all the time
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Afternoon all. After lots of searching I’ve given in and hoping someone has the answer or at least some pointers! Eas pump running all the time, no faults and tank is holding as it’ll raise and lower etc. it runs gets to cut off then dumps a bit of air and goes again in constant cycle. Checked as much as I can for leaks, bags don’t drop when parked up. Levelling ecu had a fault I can’t clear c1a00 from memory?
Post #662380 20th Apr 2023 1:53pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Relay contacts welded closed? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #662405 20th Apr 2023 6:31pm
Jimes256
Good shout but sadly not. I think there’s a problem with control ecu. Not sure if it should be in tight tolerance mode but the steering angle value doesn’t change
Post #662444 21st Apr 2023 12:58pm
Jimes256
Post #662445 21st Apr 2023 12:58pm
Jimes256
Post #662446 21st Apr 2023 12:58pm
You could try pulling the fuse on the compressor and then see what happens as you continue to use the car. My money is on a leak. Thumbs Up
Post #662471 21st Apr 2023 7:51pm
Jimes256
Their filter cansister o ring had a leak but that didn’t sort it. Somehow it was stuck in tight tolerance mode and couldn’t clear with snap on so top of the range autel sorted it back to normal
Post #662480 21st Apr 2023 9:12pm
One thing worth trying is to put the car into off road mode and leave it at least overnight, preferably longer, to see if anything happens. The front airbags tend to conceal leaks when in normal mode.
Post #662497 22nd Apr 2023 6:50am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
what is full fault code?
Post #662560 22nd Apr 2023 8:56pm
