Home > Technical (L322) > Eas pump running all the time |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Relay contacts welded closed? BMW i3 Electric Car
20th Apr 2023 6:31pm |
Jimes256 Member Since: 14 Mar 2021 Location: Bath Posts: 34 |
Good shout but sadly not. I think there’s a problem with control ecu. Not sure if it should be in tight tolerance mode but the steering angle value doesn’t change |
21st Apr 2023 12:58pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
You could try pulling the fuse on the compressor and then see what happens as you continue to use the car. My money is on a leak. |
21st Apr 2023 7:51pm |
Their filter cansister o ring had a leak but that didn’t sort it. Somehow it was stuck in tight tolerance mode and couldn’t clear with snap on so top of the range autel sorted it back to normal |
21st Apr 2023 9:12pm |
One thing worth trying is to put the car into off road mode and leave it at least overnight, preferably longer, to see if anything happens. The front airbags tend to conceal leaks when in normal mode. |
22nd Apr 2023 6:50am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 162 |
what is full fault code? |
22nd Apr 2023 8:56pm |
