Home > Maintenance & Mods (L322) > what to use-removing old glue from doors |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
For the thick build up of adhesives, after solvent, try using fishing line to cut most of it off.
19th Apr 2023 6:49pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
have a look at powerful uk and get one of their rubber wheels I have used one and can recommend it removes all of the glue and double-sided tape new vehicle purchase
19th Apr 2023 7:59pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
@oggy. -is this why you mean?
19th Apr 2023 8:41pm |
yes spot on thats the one i also use tar remover which will make it soft and help new vehicle purchase
19th Apr 2023 8:57pm |
As for which solvent, as above, tar remover seems to work, especially if you can find some gel type as opposed to fluid, then you can leave some on for a while. |
20th Apr 2023 7:13am |
