Home > Technical (L322) > L322 TDV8 Oil Change |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
Cheers for that heads-up DrRob... Yes I did have bit of a search, but that looooooooong thread escaped me I reckon. Yes the hot and cold temps variations need gradual or slow (top-up) gauging I can see that now - thanks. |
17th Apr 2023 4:52pm |
Yes the old vacuum device is certainly a handy bit of kit to have around - just right for slight overfills, which I did once a few years ago. Ta... |
17th Apr 2023 4:55pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
You're welcome! If it's just for a mid service oil and filter change then you're welcome to use mine on my drive in Petersfield one weekend. I'll even make a brew Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
18th Apr 2023 7:45am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3252 |
MSM is pushing the falshood that you need to get the oil level exactly right in order to create frustration and thus disillusion with the ICE and buy an EV 2012 TDV8 Vogue (L322) |
18th Apr 2023 8:12am |
JG:
18th Apr 2023 8:48am |
Thanks for the offer DR... Very nice of you. The temptations of a cup o tea and a FF chit chat are well worth a trip from my south east coastline to your locale... But we've just (local mobile engineer and me) recently done the full drain with belly-pan off and specifically as I'm sure the Land Rover garages and other have probably been sucking the oil out over the last few years that I've had her, and so I wanted to fully (well nearly as not draining the few hundred mills turbos oil) drain from sump this time, whilst in plain view, where I can see it being done. Plan doing big service as have ideas to move her on soon and want next owner to have full service (as opposed to what LR give: a stroke and a tickle) to be getting on with. Bloody air filter box screws are apparently hard to come by at present says my mobile guy - as he wants to replace all as half are seized - which is having me suspect that nobody who has serviced my L322 in the four and a half years I've had her has ever changed the air filters?!? Only done 13,000 miles in her though, so not quite so bad maybe. |
18th Apr 2023 9:05am |
No probs. I got my air box filter screws from Jaguar dealer instead of LR. Cheaper too. Don't ask!!
18th Apr 2023 9:15am |
Thanks for that Rob...
18th Apr 2023 9:56am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
I’m planning an oil change ( engine, differentials & transfer box ) soon. I plan to buy manual pumps to do extract & refill.
18th Apr 2023 4:44pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
[/quote]You're welcome! If it's just for a mid service oil and filter change then you're welcome to use mine on my drive in Petersfield one weekend. I'll even make a brew [/quote]
19th Apr 2023 5:21am |
CHOCOLATE HOBNOBS?!? |
19th Apr 2023 6:15am |
Tea and coffee only. Guests bring the biscuits 😂 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Apr 2023 6:20am |
