Home > Technical (L322) > L322 TDV8 Oil Change
Jayk69
Hi all,
has anyone used a Sealy Oil pump to do an oil change?
I like the vacs some folk use but this would extract directly to my oil waste container.
https://www.ebay.co.uk/itm/Sealey-TP9312-E...0010.m2109
thoughts please
Post #572184 8th Nov 2020 4:40pm
Pawl
Yes,
I use one (on our 3.6 TDV8) to get the majority of the oil out before removing drain plugs & getting the last dregs out.
Far less messy than just using the drain plugs & quicker as I no longer waste time cleaning-up all the oil that bounces off cross-members etc Laughing
It may be obvious. but get the engine warm first, so the oil flows easily.
I think I bought my pump from machine Mart in 1 of their discount days. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #572185 8th Nov 2020 4:47pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
That Sealey pump is identical (other than the stickers) to the one I use which I bought from Lidl Thumbs Up
 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #572186 8th Nov 2020 4:54pm
Jayk69
Well that's my mind made up Lidl don't have them at the moment so will spend the whopping £20 on the Sealy one.
thanks Chaps Thumbs Up
Post #572195 8th Nov 2020 6:11pm
Jayk69
Just an update on my experience with the electric pump used to remove the oil.
it is slow took about 20mins to get all the oil out so the vacuum syphon seems to be a much faster experience. it did pull out all the oil a little over 9ltrs and while it was doing its stuff i changed the air filters, oil filter and the cabin filter.
i think i will invest in a compressor next Mr. Green 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #574500 29th Nov 2020 9:55am
Pawl
Wow, that's slower than I'd expect.
Your comment made me just check what I have & its the MachineMart own brand, Clarke pump - not Sealey - although they look very similar.
This one, although now a lot more expensive https://www.machinemart.co.uk/p/clarke-cft...esel-pump/
I'm sure it only takes me around 10 minutes to pull out everything that can be reached with the pump.
Did you use yours with the engine oil hot ? Paul,
Post #574543 29th Nov 2020 4:23pm
DrRob
The Draper Expert 10L is the vacuum of choice Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #574556 29th Nov 2020 5:41pm
Jayk69
yes oil was fully hot when extracted.
DrRob i think i might agree sir on this one the only advantage is i drain straight into the disposal vessel. Still i had time to do all the filters whilst waiting Mr. Green and it did extract all the oil it could. 2012 Vogue 4.4 TDV8 - Current
Post #574558 29th Nov 2020 5:49pm
Jayk69
just an update since the service on my Fatty. The engine seems so much quieter (I already though it was quiet) and pick up seems more responsive too. not noticed MPG increase but over all much quieter, i can only think the last lot of oil was sub par or the wrong grade even cold start in the morning it does not seem to give that diesel clatter.
it might be a combination of oil service and new air filter (Already pointed out how bad the primary air filter was)
anyone offer any suggestions? 2012 Vogue 4.4 TDV8 - Current
Post #574740 1st Dec 2020 10:36am
ur20v
A Trap
Blank your egr’s and the oil will stay cleaner and last better! I haven’t blanked egr’s before but am amazed by how clean the oil stays, it’s almost petrol like for how the oil stays clear. Coming from an ex-master tech who has serviced many 1000’s of cars over the years.
Post #574748 1st Dec 2020 11:44am
Fox889
ur20v: I don't believe you can blank the EGR's on a 4.4 TDV8, something to do with the ECU........but stand to be corrected. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #574754 1st Dec 2020 12:26pm
Jayk69
yes i hate the fact i cannot keep engine oil clean in a diesel. I used to have the original Focus RS that was a 400HP monster i did 80k in it fully tuned i used to do an oil change every 3k and it came out like it went in!!
but i have read over and over that EGR delete on this particular engine is not generally recommended like the 3.6. the only people who recommend it are the tuning houses and they have a financial interest in you doing it and having a subsequent re-map.
for the oil i will compensate with 6k oil change as it is quick and easy to do.
but to consider EGR blanking i would need to see evidence it will not ruin a great engine. 2012 Vogue 4.4 TDV8 - Current
Post #574761 1st Dec 2020 1:27pm
DrRob
4.4 needs the EGR to work for DPF etc.
Some chap on Facebollocks has done it but it sounded very Heath Robinson Whistle Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #574763 1st Dec 2020 1:31pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Reading this thread had me thinking about the ideal or accepted oil level setting as far as the electronic instruments screen readout goes...
Most of my previous oil/filter services have had the electronic level arriving at around the upper mark - almost at overfilled... Many services I've watched on Youtube (Sam etc) have filled engine to the middle or OK oil level... and maybe seen how things run before topping or not topping...
Question is: What would members here at FF consider as best oil level to be happy with?
Neutral
My baby is the trusty L322 2012 Westy with 63,000 miles
We just did the two diffs and transfer box also recently...
Post #662088 17th Apr 2023 9:53am
DrRob
I have mine at one or two notches above mid point when COLD.
20mins post shut down of a HOT engine it shows at top of scale.
I use around 8.3L to achieve this following vacuum extraction.
Anymore oil than this and it will defo show Overfilled when checked HOT.
There is a loooooooooooong thread on this somewhere on here Thumbs Up Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #662104 17th Apr 2023 12:50pm
