Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
Starting to really wonder if this is all in my head...
16th Apr 2023 8:39am |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 44 |
Probably only way to be sure is to try another similar car back to back and compare how they feel. Maybe try a test drive at a local garage if possible. 2013 SDV8 4.4 Vogue SE Aintree |
16th Apr 2023 8:54am |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 134 |
I am new to the RR as well. only had it 2 weeks.
16th Apr 2023 8:55am |
I thought that too Phil,
16th Apr 2023 9:25am |
My dad has a disco 3 and the steering is deffo lighter. It does not annoy me, I just remember on the test drive it was the very first thing I noticed.
16th Apr 2023 9:38am |
See that doesn't seem right to me, the Range Rover should be the most comfortable, easiest to drive model in the lineup.
16th Apr 2023 9:57am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1388 |
If you are still running with tyres at below the recommended pressure that will make your steering heavier. Only Range Rovers since 1988 |
16th Apr 2023 10:07am |
No back at the factory pressures of 34 front 37 rear now. |
16th Apr 2023 10:11am |
once it gets in your head its very hard to forget about it, talking from experience X5 40d |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
Whereabouts in the North West are you..?? Pete
16th Apr 2023 10:32am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
If you’re preparing to sell the car might I suggest it’s time to let a professional look at it? Rule things out once and for all! Get a definitive answer… |
16th Apr 2023 10:58am |
Not planning to sell any time soon Craig, only bought it recently!
16th Apr 2023 11:17am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Unfortunately MarianaWestminster, it’s something you are focussing on and looking for. Because of this you are more sensitive to the ride quality and will be more critical because of it.
16th Apr 2023 1:06pm |
Oh, just a thought…
16th Apr 2023 1:07pm |
