![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
Okay, I'll get it booked in for road force.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
roadforce is for wheel balancing, hawkeye is for wheel alignment... |
Thanks Stan, the plan so far is a road balance on the wheels then an alignment by hawke eye if I can find someone with it if not Hunter.
hunter is the manufacture, so its a hunter hawkeye...confusing isnt it.. |
Ah right my mistake, Hunter Hawkeye it is |
Right got an interesting one for you guys to puzzle over...
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
You can switch auto lower off, and would need to be switched off during a geometry setup... You can also manually lock your car into any height you wish. Simply hold the suspension lock button for 3 or 5 seconds... This might help you diagnose your problems? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2578 ![]() ![]() ![]() |
Do you have a lock button that isn't on the lower button? The one on the lower button locks access height for a faster speed in underground carparks. |
Yes I could switch auto lowering off and just leave it in normal height for a bit to see how I get on.
i wonder why the ride would be affected like that....after access mode, could it be the compressor is struggling to pump enough air into the system to give a good ride..
Seams really odd I have to say… Certainly shouldn’t make a difference…
It had a new compressor about a month back Stan under LR warranty as it was throwing up normal height only due to the original being tired.
For the record, locked at access height has a maximum speed of 40 kph, above which the vehicle will raise to normal height. |
