Home > Technical (L405) > Ride quality -16 SDV8 AB
Page 2 of 35 <123 ... 333435>
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
That would be my next step as Road Force seems to be the most likely to give that 'new car' ride.
Not tried it myself but lots of good reports.
Have you had the dynamic response fluid changed as I noticed a small improvement?
Post #661414 9th Apr 2023 10:12am
MarianaWestminster
Okay, I'll get it booked in for road force.
I used Neinmeister Porsche in Warrington for a road force on my Bentley and it did bring a good improvement.
Post #661423 9th Apr 2023 11:38am
roadforce is for wheel balancing, hawkeye is for wheel alignment... Thumbs Up ... - .- -.
Post #661424 9th Apr 2023 11:43am
MarianaWestminster
Thanks Stan, the plan so far is a road balance on the wheels then an alignment by hawke eye if I can find someone with it if not Hunter.
Will update Thumbs Up
Post #661430 9th Apr 2023 1:21pm
MarianaWestminster
Post #661431 9th Apr 2023 1:21pm
hunter is the manufacture, so its a hunter hawkeye...confusing isnt it.. Laughing Thumbs Up ... - .- -.
Post #661432 9th Apr 2023 1:28pm
MarianaWestminster
Ah right my mistake, Hunter Hawkeye it is Laughing
Post #661433 9th Apr 2023 1:33pm
MarianaWestminster
Right got an interesting one for you guys to puzzle over...
So my RR has auto access height and with me having it turned on it drops to access whenever I alight the vehicle.
Driving away it raises itself back up as you'd expect.
Me and my partner met up with friends tonight and whilst sitting in the car talking before leaving I manually raised the suspension up to normal height from access.
On the drive home the suspension felt much better damped and just better over all compared with the drive down (about a 40 minute trip)
That makes no sense to me but I'll do some testing and see if it's repeatable!
Any thoughts on this greatly appreciated Question
Post #661452 9th Apr 2023 9:02pm
You can switch auto lower off, and would need to be switched off during a geometry setup... You can also manually lock your car into any height you wish. Simply hold the suspension lock button for 3 or 5 seconds... This might help you diagnose your problems? Thumbs Up
Post #661458 10th Apr 2023 12:54am
GraemeS
Do you have a lock button that isn't on the lower button? The one on the lower button locks access height for a faster speed in underground carparks.
Post #661461 10th Apr 2023 1:56am
MarianaWestminster
Yes I could switch auto lowering off and just leave it in normal height for a bit to see how I get on.
I only have the ability to lock in access height as far as I'm aware.
Holding the down button with the lock just lowers and locks the car to access height when in normal height.
Just weird how that seemed to make a difference doing what I did last night, will test over a few days and perhaps measure heights when allowing the car to automatically rise to normal height vs me manually selecting normal height
Post #661464 10th Apr 2023 7:37am
i wonder why the ride would be affected like that....after access mode, could it be the compressor is struggling to pump enough air into the system to give a good ride..
..or maybe a sensor somewhere? ... - .- -.
Post #661466 10th Apr 2023 8:23am
Seams really odd I have to say… Certainly shouldn’t make a difference…
That said, it’s not hard to damage components driving it in lowered mode up a badly made track! Always good practice to press the up button before you drive away…
Post #661471 10th Apr 2023 9:47am
MarianaWestminster
It had a new compressor about a month back Stan under LR warranty as it was throwing up normal height only due to the original being tired.
Craig, I see what you mean but in my ownership its only seen paved roads so far so hasn't been driven on any bad tracks in access height.
I'm sure it was fine when I bought it and drove it home Laughing
Post #661480 10th Apr 2023 10:29am
GraemeS
For the record, locked at access height has a maximum speed of 40 kph, above which the vehicle will raise to normal height.
Post #661482 10th Apr 2023 11:00am
