![]() | Home > Maintenance & Mods (L322) > Uneven Front Discs |
JDRR Member Since: 04 Apr 2023 Location: Kent / Sussex Posts: 11 ![]() ![]() ![]() |
Is there a common problem with uneven disc wear?
ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 48 ![]() |
Sounds more likely to be the pad material and/or the pad backing plates - e.g. Mintex are notorious for being noisy, and if the back of the pads aren't greased properly, they can squeal too |
N.B -
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3243 ![]() ![]() ![]() |
Warped disc? John
Weirdly, it doesn’t exhibit any other warped disc symptoms, no vibrations or wobbling under braking or high speed |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
There will be a minimum thickness stamped into the outside lip of the disc bell... Use some callipers and measure what thickness is left would be a good starting point...
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
As above, if it were me I would be changing the discs / pads asap, if there is a step in the disc surface, then it will be useless fitting new pads. Whilst this is being done, also check the callipers in case this has been a possible cause of any problems. |
Thanks all, I’ve got some Brembo discs to put on, but any pad recommendations?
