Home > Maintenance & Mods (L322) > Uneven Front Discs
JDRR
Uneven Front Discs
Is there a common problem with uneven disc wear?
Picked up my 2011 4.4TDV8 last week and the front brakes squeal loudly when low speed braking.
There’s no brake wear light on, and the pads seem to have plenty of material left, so I’ve had a look over the disc surface and the outer is a lot higher than the rest of the disc with a noticeable step up.
Is it likely someone's fitted pads that are too small? I’ve read there are a fair few variations in Caliper size over the build years.
Thanks
Post #661351 8th Apr 2023 1:38pm
TDV8 Paul
This is normal disc wear- possibly the previous owner hasn’t changed the discs as often as they should and just got away with new pads 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #661352 8th Apr 2023 2:03pm
ttrw2
Sounds more likely to be the pad material and/or the pad backing plates - e.g. Mintex are notorious for being noisy, and if the back of the pads aren't greased properly, they can squeal too
Post #661353 8th Apr 2023 2:03pm
JDRR
N.B -
When I say the outer is higher, I’m not referring to the disc having a large lip, it’s the actual braking area/surface of the disk that has a step in it!
Post #661355 8th Apr 2023 2:15pm
Weegie
Warped disc? John
GAP iiD BT
Post #661360 8th Apr 2023 3:15pm
JDRR
Weirdly, it doesn’t exhibit any other warped disc symptoms, no vibrations or wobbling under braking or high speed
Post #661364 8th Apr 2023 4:11pm
There will be a minimum thickness stamped into the outside lip of the disc bell... Use some callipers and measure what thickness is left would be a good starting point...
But remember, you can't put a price on safety sir... If in doubt, id change them... Thumbs Up
Post #661388 8th Apr 2023 11:43pm
Merchy
As above, if it were me I would be changing the discs / pads asap, if there is a step in the disc surface, then it will be useless fitting new pads. Whilst this is being done, also check the callipers in case this has been a possible cause of any problems. Thumbs Up
If the discs are in such poor condition, then this could possible point to poor or inadequate maintenance in the past Question It only takes seconds to run your fingertip over the disc surface to carry out a rough check, but remember to do so when the discs are cool Whistle
Post #661390 9th Apr 2023 2:25am
JDRR
Thanks all, I’ve got some Brembo discs to put on, but any pad recommendations?
I’m assuming getting some Genuine Pads from a Main Dealer costs the earth?
Was thinking of getting a set of these:
https://www.advancedfactors.co.uk/lr114004...7643-p.asp
Will be stripping down the brakes today to see if the uneven wear translates to the pads / if there’s a caliper issue
Post #661401 9th Apr 2023 7:54am
