Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
Any input to this?
7th Apr 2023 9:35pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
Ride quality is very subjective, my 2014 Ab running on the same tyres is good but not perfect, ridges across the road upset it's composure and it tramlines on poor surfaces....
8th Apr 2023 8:52am |
I feel similar Haylands...
8th Apr 2023 10:45am |
P.s. I also notice its worse in cold weather I.e harsher! |
It's the wide tyres that make it tramline, I was thinking of dropping to the 20" wheels and narrower tyres when these 21's wear out...
8th Apr 2023 12:22pm |
portrobc Member Since: 17 Mar 2017 Location: Evesham Posts: 63 |
I would agree with all your sentiments expressed above. I am running a 2016 5.0SC on 21's and after the initial honeymoon period I thought the same, tramlining, skittery and so forth.
8th Apr 2023 5:57pm |
Glad it's not just me portrobc!
8th Apr 2023 6:06pm |
I am running 34 p.s.i. all round.
8th Apr 2023 7:54pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1388 |
My 2017 5.0SC on Pirelli Sc Verde 275/45R21 is the same, tramlining and reacting to the very poor road surfaces found in parts of Scotland. I run Goodyear Duratrac 255/55R20 in the winter and they don't do that. I think the lateral grooves on the Pirellis respond to ridges etc in the road surface and the car moves about in a manner I consider inappropriate for a RR. This at 37 psi rear and 34 front (when not towing), which I think is what LR recommend.
8th Apr 2023 8:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
A well set up fatty is something sublime! A poorly setup fatty is NOT a nice place to be... Im lucky I drive many on a daily basis. You usually can tell within a mile or 3 if they're not right...
8th Apr 2023 9:30pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Ours was awful after the Main Dealer did some work on it, they insisted it was spot on but reluctantly re set it back up geo wise and it was still awful!
9th Apr 2023 7:36am |
Okay so quite a few are talking about geo/alignment but my question is will having this setup properly cure the 'jittery' unsettled feeling I get?
9th Apr 2023 8:03am |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 59 |
That sounds more like wheel balance?. These are super sensitive to it as the adaptive dynamics will try to cancel out a vibration on a particular corner by stiffening a damper, which in turn can cause a jittery ride. |
9th Apr 2023 9:44am |
Yes I've heard of that Qwerty.
9th Apr 2023 10:07am |
