![]() | Home > Technical (L322) > 2008 l322 TDv8 Ac condenser fan running at full speed. |
Crikey2008 Member Since: 22 Mar 2023 Location: Nepal Posts: 6 ![]() ![]() |
Some scantool data .
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2653 ![]() ![]() |
Have you tried another relay?
No fan relay for the same engine and radiator group in the RRS either, so the PCM has to be controlling it.
No dtcs stored.
Maybe not helpful, but I'm reminded of a very early (1st batch 1999) TD5 D2 that I owned that ran the cooling fan constantly with the ignition switched on if the coolant temperature sensor signal had been invalid (the sensor had been disconnected). The fault wouldn't clear so a new ECM had to be fitted.
Thank you for the suggestion. I will try and get hold of another scantool.iam using a launch x431 at the moment. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Have you tried changing the Final Stage Resistor (FSR)... a common fault which effects the fan...
I have a new fsr and will try that tomorrow.
Sorry, misread the first post.... |
