Home > Technical (L322) > 2008 l322 TDv8 Ac condenser fan running at full speed.
Crikey2008
India
Greetings from Nepal! I run a small workshop here, not a lot of experience with euro cars. We get mostly asian makes.
I need some assistance with a 2008 rangerover tdv8.
The ac condenser fan runs at full speed when the vehicle starts.
We replaced the old one since it was not coming on when the ac was switched on .
The fan has three wires going to it .
A constant +ve , a constant -ve. And a thin wire which I think is the control wire.
When I switch the ignition on the fan doesn't come on , but if I ground the control wire with a test light it switches on .
I tried disconnecting the HVAC control unit in the vehicle, but still the fan comes on .
The ambient temp, engine temp , are all within spec.
Bi -ditectional activation of the fan speed is possible when the key is on the on position .
Any help would be greatly appreciated.
Thank you !.
Post #660008 22nd Mar 2023 2:06am
Crikey2008
India
Some scantool data .
The ac compressor relay is on the on state. Even when the ac switch is not switched on .
The ac compressor clutch state does come on when switch is pressed and goes off when it's not pressed.
Post #660010 22nd Mar 2023 2:19am
GraemeS
Australia
Have you tried another relay?
Are there any DTCs stored in the PCM?
Post #660012 22nd Mar 2023 3:32am
Crikey2008
India
There seems to be no relay for the ac compressor or the condesor fans according to the wiring diagram.
Post #660014 22nd Mar 2023 6:33am
GraemeS
Australia
No fan relay for the same engine and radiator group in the RRS either, so the PCM has to be controlling it.
Have you checked for DTCs in the PCM? Presumably a battery disconnect has been tried.
Post #660016 22nd Mar 2023 9:57am
Crikey2008
India
No dtcs stored.
Yes a battery disconnect has been tried aswell with no luck .
Post #660017 22nd Mar 2023 10:00am
GraemeS
Australia
Maybe not helpful, but I'm reminded of a very early (1st batch 1999) TD5 D2 that I owned that ran the cooling fan constantly with the ignition switched on if the coolant temperature sensor signal had been invalid (the sensor had been disconnected). The fault wouldn't clear so a new ECM had to be fitted.
Do you have access to a different scan tool in case it can find another DTC? If your tool is an IIDtool then have you set it to show all faults, as the devices are distributed with 1 required option unchecked (pending faults IIRC).
Post #660019 22nd Mar 2023 10:31am
Crikey2008
India
Thank you for the suggestion. I will try and get hold of another scantool.iam using a launch x431 at the moment.
Post #660021 22nd Mar 2023 10:41am
Have you tried changing the Final Stage Resistor (FSR)... a common fault which effects the fan...
Youtube has videos on doing it, not a bad job...
If you plan on keeping the car buy genuine... Thumbs Up Pete
Post #660035 22nd Mar 2023 3:02pm
Crikey2008
India
I have a new fsr and will try that tomorrow.
I thought it only affects the blower motor though .
Post #660039 22nd Mar 2023 3:08pm
Sorry, misread the first post.... Bow down Pete
Post #660045 22nd Mar 2023 5:23pm
