![]() | Home > Technical (L322) > Starting problems |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
The battery in the fob ? |
Bluestu33 Member Since: 31 Dec 2014 Location: Cambridgeshire Posts: 69 ![]() ![]() ![]() |
Thanks!
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Also, make sure the battery is a good one, e.g. Duracell, Varta 2015 Range Rover Autobiography 4.4 SDV8 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Sounds to me like it may also be a starter motor issue? The 4.4TDV8 does suffer failures regularly I'm afraid... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
My cash is on a starter motor. Had it myself and seen it a fair few times on here. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
before splurging on the starter motor do the following
Battery in the remote first.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
A very well known issue is the trigger wire from the starter relay to the starter solenoid not being able to carry enough current to cause the solenoid to be operated with sufficient force to hold less than perfect contacts closed.
