Home > Technical (L322) > Heavy steering at low speeds...TD6
Superspoons
Morning,
All is going well with our new TD6 but I've noticed how heavy the steering is at low speed when, for instance, doing a 3 point turn. Anything below 10mph takes a lot of effort to turn the wheel.
Is this a ' feature' of the TD6? My previous 4.4 never had an issue - finger light steering at whatever speed. It's got a years LR warranty so if there is a problem Id like to get it sorted.
cheers, Gavin
Post #65980 27th May 2011 6:57am
Sounds like you need the servotronic valve on the steering replaced
Post #65981 27th May 2011 7:15am
mine had the same symptoms, replaced the servotronic valve [£50/60] and problem now gone..
Post #65986 27th May 2011 7:34am
Superspoons
Thanks for all the replies - This should be covered on the LR Warranty???
thoughts.... Question Gavin
Post #66062 27th May 2011 4:27pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Yep sounds like servotronic valve, should absolutely be covered under warranty! 2008/58 FFRR 3.6 TDV8 Vogue
Post #66081 27th May 2011 8:56pm
