![]() | Home > Maintenance & Mods (L322) > SC 5.0 Brembo Brake Bleeding |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
There is a specific sequence to pressure bleed in the WM..
I can't recommend a particular model but just avoid the cheap ones that use you spare tyre as a pressure source. If you have an air compressor in your workshop there are good ones that can use this. 2012 TDV8 Vogue (L322) |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 199 ![]() ![]() ![]() |
Thanks JayGee :thumbs up |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1592 ![]() ![]() ![]() |
I got one of these:
At the risk of opening a whole new can of worms (which I’m good at) ![]() The threads are outboard of the sealing cone, so the PTFE shouldn’t be able to get into the brake fluid anyway. You have to be careful only to tape the threads and nothing more. Has it worked? Dunno, maybe I’ll find out in a few years’ time ![]() |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 117 ![]() ![]() |
They all opened albeit with a bit of a creak. Front ofs outboard didn’t have any flow so I’ll get a new nipple for that one. Although I might take it out and try and poke a bit of wire in it to see if there’s just a blockage. Pedal better but I suspect will be even better with that 4th nipple bled properly Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
@goldstar,
You’re absolutely right and I did just that about 10 mins ago. 👍 Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
Use this stuff, it will sort your nipples out.... |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 869 ![]() ![]() ![]() |
I can agree 100% - I got two 56g tubs, have used it on all our cars for bleed nipples and also used it sparingly on wheel studs ( the passenger side wheel nuts get a lot of exposure to our salty roads in the winter and now no rust on them, well the six cars I have looked at anyways) AMAZING STUFF !
