Home > Maintenance & Mods (L322) > SC 5.0 Brembo Brake Bleeding |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Long story short: Brembo brakes are harder to bleed.
8th Jul 2016 3:21pm |
Just realised this is in the wrong section:
8th Jul 2016 3:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
done ... - .- -.
8th Jul 2016 3:23pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1507 |
Hi Goldstar,
4th Mar 2023 11:57pm |
WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27 |
Good shout Gremlin500🤞 Willie
5th Mar 2023 12:33am |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
Glad Goldstar raised this.
5th Mar 2023 8:51am |
@Nylands,
5th Mar 2023 8:56am |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 117 |
Thanks Gremlin. I should have mentioned that I have an IID - does that do the job of a proper bleed does anyone know? Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
5th Mar 2023 9:13am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
AFAIK the GAP has an ABS purge function but not sure if this is the same as a full brake bleed function. The main issue for most will also be the fact that the bleed nipples will be galvanicaly seized in the calliper body so bleeding the brakes will be impossible anyway. 2012 TDV8 Vogue (L322) |
5th Mar 2023 9:18am |
You’re not helping my optimism Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
5th Mar 2023 10:04am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8276 |
I can't see that changing the front callipers needs a diagnostic tool, I find gravity bleeding works well... Open the bleed nipples, keep the reservoir filled up and wait till it drips out cleanly with no bubbles... always worked for me and this way prevents the system sucking in air.....
5th Mar 2023 10:33am |
Very helpful thank you. I’ll try bleeding them and see what happens. Cheers Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
5th Mar 2023 10:36am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 745 |
Yes the IID does do a bleed sequence - it even tell you which sequence to bleed the calipers, I can't remember the details of it but I did have to do it twice - I think it was just my inability to follow instructions. |
5th Mar 2023 10:41am |
Gravity bleeding isn't very good with air trapped in the lines as it will simply rise up against the flow. Better than trying to suck fluid out which is the worst method. Pressure bleeding is best IME but you need a good unit that can provide the right amount of pressure and they are not cheap. 2012 TDV8 Vogue (L322) |
5th Mar 2023 11:07am |
