Home > Maintenance & Mods (L322) > Leaky Throttle Body not in the usual place |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Whilst i was dismantling the part of the car to sort a squeaky aux belt, i removed the throttle body. I’ve got oily deposits around the area suggesting there is a leak but not found the location of the leak. I’ve taped the throttle body in the past in an attempt to try to fix it… but to no avail.
25th Feb 2023 12:59pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
If you are talking about the large green "O" ring then yes it is available with the whole pipe....!!!!
25th Feb 2023 1:22pm |
Let’s try including the picture I took this time! Makes things a little easier…
25th Feb 2023 1:45pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
I put a new one on mine. Part number LR022931. About £3. |
25th Feb 2023 2:42pm |
Spot on! Thank you very much
25th Feb 2023 4:12pm |
Shouldn't have a kink mate. |
25th Feb 2023 4:24pm |
25th Feb 2023 4:26pm |
Then clearly mine is a bit “tired”!
25th Feb 2023 4:46pm |
That's a nice cheap fix... Pete
25th Feb 2023 7:36pm |
All replaced and very quick and easy.
6th Mar 2023 6:00pm |
