Home > Maintenance & Mods (L322) > Leaky Throttle Body not in the usual place
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Whilst i was dismantling the part of the car to sort a squeaky aux belt, i removed the throttle body. I’ve got oily deposits around the area suggesting there is a leak but not found the location of the leak. I’ve taped the throttle body in the past in an attempt to try to fix it… but to no avail.
However today i see oil around the seal where the Throttle Body attaches to the plenum! The bolts were tight when i removed them, and the washer (?) does not protrude by the same amount all of the way around. At its worst it is flush with the housing.
I suspect this is a replaceable part? But would not be suprised if its something that only comes with a whole ‘something’ else…
Does anyone know what this part is, and how I replace it? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #657731 25th Feb 2023 12:59pm
If you are talking about the large green "O" ring then yes it is available with the whole pipe....!!!!
Do a search, people have come up with various fixes.... Thumbs Up Pete
Post #657732 25th Feb 2023 1:22pm
Ffrr-lover
Let’s try including the picture I took this time! Makes things a little easier…
Cheers for the response Haylands. Its not the pipe end… but where the throttle body bolts to… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #657735 25th Feb 2023 1:45pm
kevinp
I put a new one on mine. Part number LR022931. About £3. Thumbs Up
Post #657739 25th Feb 2023 2:42pm
Ffrr-lover
Spot on! Thank you very much Very Happy
In my photo there is a kink in the right hand side which I cannot see in the photos with that product code. Does it come with a kink? Or does that not matter? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #657755 25th Feb 2023 4:12pm
kevinp
Shouldn't have a kink mate.
Post #657759 25th Feb 2023 4:24pm
kevinp
Post #657760 25th Feb 2023 4:26pm
Ffrr-lover
Then clearly mine is a bit “tired”!
Cheers for confirming Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #657766 25th Feb 2023 4:46pm
That's a nice cheap fix... Thumbs Up Pete
Post #657803 25th Feb 2023 7:36pm
Ffrr-lover
All replaced and very quick and easy.
Next for me is to replace the other seal as mentioned on other threads… the PTFE tape fix will do for now tho… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #658670 6th Mar 2023 6:00pm
