![]() | Home > Technical (L322) > strange gearbox question |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Could just be a linkage probem. Does it have any issues starting if you move the gear lever slightly in park?, which would indicate a linkage problem.
joninprague Member Since: 29 Dec 2022 Location: surrey Posts: 26 ![]() ![]() |
Thanks, No they have not had any work done to it but its about the mileage the gearbox oil should be replaced from what I have read.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
My money is a one the linkage being the problem, get under and see how corroded it looks and get it freed off and lubed up. |
Bloody fat finger on phone
It's all pointing towards the linkage. To be honest the six speed gearboxes are pretty good. |
Thanks Gents. if I manage to get it I will get straight underneath |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Check this out
So picked the car up yesterday and drive home with out any real problems. I did have to just keep gearstick back to keep it in gear. The other gears work perfectly as do reverse. It does have an small problem as although the light shows its in park.
so plugged in the icarsoft and it came up with the code p0826. I have looked at the gear selector and seems to move ok but sounds a little clunky. I will attach a short video if I can figure out how |
so managed to upload to youtube on the link below
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
That photo just shows a pipe clip?
Just as a little update the brake issue was the rear drivers side brake hose was leaking so I have bought 2 to do both sides.
Hi All,
