![]() | Home > Maintenance & Mods (L322) > wheel arch liner removal, rusty subframe |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
this is the main picture for the promotion of lanoguard explaining why sheep have so much oil in their fleeces it is what they get up to the more energetic things they do in turn makes more oil that is produced. i bet no one has ever thought about what sheep breed makes the best oil is it heard wicks from Cumbria or the good old well-known Dorset ewe
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
Could you explain that a bit more for me please? Do you mean at the very rear of the arch? A picture would be great ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Do you know the sizes to hand? Cheers. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 ![]() ![]() ![]() |
Yes dhallworth, regret buying it on that basis but I'll use it now. |
kevinp why don't you use the sheep oil in places like around the engine bay inside the bonnet front panel and .inside the door areas behind the door panels when you remove them? around the tailgate hatch inside the lower tailgate in places it does not get so much wear and is a lot cleaner to use in the above areas. that is where I shall use mine when it comes new vehicle purchase
Yes oggy, good idea. I did a thorough waxoiling when I first got the car to the chassis and box sections.
hi drRob i will get back to you with more details and pictures I will be going to the workshop tomorrow new vehicle purchase
hi DrRob the fixings i used are . 6mm x 25 mm od washers. and the fixings are called hexagon head self-tapping screws size 6 x 19 mm and I got new lot of plastic clips for the very rear fixings. the rear arch strip that is being used in the vid the chap cuts it in 2 which you don't have to you can run it from the back to the front in one piece. the return lip on the arch I masked a line on the outer edge just retuning the masking tape underside then removing any places that had paint peel etc . then put on a coat of epoxy resin let it dry the next day put a bead of seam sealer a pu sealer like tiger seal on the return edge and smoothed it out with my finger then a second coat of epoxy resin the seam sealer helps the barbs on the u trim grip and holds it in place. and also the seam sealer helps with any stones etc hits that instead of the paintwork . new vehicle purchase
markturner Member Since: 06 Dec 2022 Location: New Romney Posts: 12 ![]() ![]() ![]() |
Thanks, its these ones:
Yeah, I get that, but I think if you care enough about the car to go to this trouble, its going to be getting loads of cleaning and brushing anyway and after a year, I would say most coatings would need sorting again. I have 2 othe rcars, both of which I did complete underside jobs on, a 996GT3 and an E92 M3, ( they are NOT daily drivers though) and the issue I had was that most protective coatings are sticky and road dust and mess just sticks to them and makes a nasty coating. I like to look under the car and see the clean and shiney metal and rubber and paint, so as they dont get used much, I just clean them every time they go for a long drive and re apply plenty of GT85, WD40 etc to all exposed surfaces. This protects the metal from corrosion and is relatively easy to wash off and reapply. With the fattie, I dont think I will be so particular, but do want something to protect the subframe etc as I dont want the corrosion thats already started to get worse. |
I think these are the ones you need to get yourself a trim tool with a v to remove them ebay for clips and trim set ![]() ![]() 2007 supercharged 4.2 java black .sand leather vogue se trim previous cars . range rover classic 200 tdi discovery 1 200 tdi freelander 2 2008 hse discovery 1 300 tdi p38 4.0 ltr man r380 ex royal support vehicle on v5c discovery td5 man off roader |
