Home > Maintenance & Mods (L322) > wheel arch liner removal, rusty subframe
kevinp
'Given the work involved and the fact it's a miserable job I'd be put off using Lanoguard every 12 months.'
I've just bought some Lanoguard but tend to agree with the above and wished I'd followed my instinct and used good old Waxoil!!
I never thought of asking myself why it needs reapplying after 12 months.
Perhaps I've followed others enthusiasm like a sheep!!!! Pun intended.
Post #656093 9th Feb 2023 11:17am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
this is the main picture for the promotion of lanoguard explaining why sheep have so much oil in their fleeces it is what they get up to the more energetic things they do in turn makes more oil that is produced. i bet no one has ever thought about what sheep breed makes the best oil is it heard wicks from Cumbria or the good old well-known Dorset ewe
just thought I would add the house walls are all potatoes . new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #656108 9th Feb 2023 12:26pm
DrRob
oggy wrote:
i have watched this vid a couple of times and it can be done better. you do not have to cut the arch trim you can bend it around the down return so it is left as one strip
Could you explain that a bit more for me please? Do you mean at the very rear of the arch? A picture would be great Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #656124 9th Feb 2023 2:45pm
DrRob
oggy wrote:
when you put all of the covers back use stainless steel fixings jobs
Do you know the sizes to hand? Cheers. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #656125 9th Feb 2023 2:46pm
kevinp
Yes dhallworth, regret buying it on that basis but I'll use it now.
Post #656129 9th Feb 2023 3:30pm
oggy
kevinp why don't you use the sheep oil in places like around the engine bay inside the bonnet front panel and .inside the door areas behind the door panels when you remove them? around the tailgate hatch inside the lower tailgate in places it does not get so much wear and is a lot cleaner to use in the above areas. that is where I shall use mine when it comes new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #656134 9th Feb 2023 3:53pm
kevinp
Yes oggy, good idea. I did a thorough waxoiling when I first got the car to the chassis and box sections.
I've recently put all new suspension arms, drop links etc on and they are rusting already.
I'll try the Lanoguard on the new parts and see how it does.
Thanks Kev.
Post #656135 9th Feb 2023 4:04pm
oggy
hi drRob i will get back to you with more details and pictures I will be going to the workshop tomorrow new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #656142 9th Feb 2023 5:55pm
DrRob
Post #656147 9th Feb 2023 7:44pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #656148 9th Feb 2023 7:44pm
oggy
hi DrRob the fixings i used are . 6mm x 25 mm od washers. and the fixings are called hexagon head self-tapping screws size 6 x 19 mm and I got new lot of plastic clips for the very rear fixings. the rear arch strip that is being used in the vid the chap cuts it in 2 which you don't have to you can run it from the back to the front in one piece. the return lip on the arch I masked a line on the outer edge just retuning the masking tape underside then removing any places that had paint peel etc . then put on a coat of epoxy resin let it dry the next day put a bead of seam sealer a pu sealer like tiger seal on the return edge and smoothed it out with my finger then a second coat of epoxy resin the seam sealer helps the barbs on the u trim grip and holds it in place. and also the seam sealer helps with any stones etc hits that instead of the paintwork . new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #656198 10th Feb 2023 11:32am
DrRob
Post #656217 10th Feb 2023 4:35pm
markturner
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
oggy wrote:
take a picture of the fixings that are giving trouble I think it is the ones that have a small pin in the centre you tap them through and use a v tool behind the round you can't recover the pin so buy some new ones cheap on eBay
Thanks, its these ones:
Post #656220 10th Feb 2023 4:57pm
markturner
dhallworth wrote:
Our local undersealing place have started to offer Lanoguard as a cheaper alternative to their normal Dinitrol stuff.
According to them, the Dinitrol stuff needs an inspection and any affected areas cleaning up and retreating every 12 months, the Lanoguard needs completely reapplying every 12 months.
Yeah, I get that, but I think if you care enough about the car to go to this trouble, its going to be getting loads of cleaning and brushing anyway and after a year, I would say most coatings would need sorting again.
I have 2 othe rcars, both of which I did complete underside jobs on, a 996GT3 and an E92 M3, ( they are NOT daily drivers though) and the issue I had was that most protective coatings are sticky and road dust and mess just sticks to them and makes a nasty coating. I like to look under the car and see the clean and shiney metal and rubber and paint, so as they dont get used much, I just clean them every time they go for a long drive and re apply plenty of GT85, WD40 etc to all exposed surfaces. This protects the metal from corrosion and is relatively easy to wash off and reapply.
With the fattie, I dont think I will be so particular, but do want something to protect the subframe etc as I dont want the corrosion thats already started to get worse.
Post #656221 10th Feb 2023 5:04pm
oggy
I think these are the ones you need to get yourself a trim tool with a v to remove them ebay for clips and trim set
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #656233 10th Feb 2023 6:46pm
