Home > My Range Rover > 2k for 06 4.2sc |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
Good job on the welding brave man...... |
6th Feb 2023 7:55pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Haven't up dated this for a while.
4th May 2024 12:28pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1204 |
Thankfully you and your daughter are ok, at the end of the day, that's all that matters. Hope you are both Fine after the incident. |
4th May 2024 1:14pm |
Cheers merchy
4th May 2024 1:19pm |
Good your both ok the rest can be replaced |
5th May 2024 5:43pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3128 |
That's a bit of luck right there given all the work you've done to it!
6th May 2024 10:30am |
Cheers gents.
6th May 2024 4:09pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Been there done that its worrying first time but as Craig says persistence is the key |
7th May 2024 3:02am |
Well that's officially the end of the car.
29th May 2024 1:56am |
Well onwards and upwards good luck with the house an d look forward to seeing you back |
29th May 2024 2:52am |
Houses go up RR go down see you soon |
31st May 2024 7:37pm |
Its on co part already. They don't hang around altho not sure they will get what they are hoping for it
4th Jun 2024 3:21am |
