![]() | Home > My Range Rover > 2k for 06 4.2sc |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
No pretend your tightening it and it'll come off lh thread |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
I done some reading on the Internet and they all said it was a rh thread |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
I ordered the tool from PowerfulUK to hold the pulley and then had a viscous fan spanner that I’ve had since my P38 days. It took a good whack with a lump hammer to get it to shift. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
I ordered the same one David. Don't suppose be much more progress now until next week though |
MY APOLOGIES , you're correct I must be thinking of the bmw engine or had a brain fart ![]() |
Try this method
Cheers for the replies gents. I went to powerful and ordered this puppy.
Tap tap and
Sadly from maltings the viscous fan hasn't turned up after issues from parcelforce but as I suspect the fan shroud don't normally appear to be in 4 various pieces
![]() Hopefully tomorrow I'll get the pump and belts off and get it put back together |
Well after the daily decided to throw a wobbly this weekend by cooking the alternator, battery and now it's overheating so left that on its own for the time being and decided to carry on with the supercharged. Managed to get the water pump and the belts off today but then the heavens decided to open and flood the road so thought this would be a good time to down tools.
Well had an early finish today from work so decided I'd get some of the car done this evening. Managed too get the water pump on and both belts put back on. Have too admit the tensioner is definitely the easiest one I've ever done in the past with a trust 3/8 ratchet.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Going in the right direction |
Sure is Mr Glover
PlaceDuPilori Member Since: 05 Apr 2021 Location: Sussex Posts: 20 ![]() ![]() ![]() |
And what is the latest update with this project? Seems like a proper result... fingers crossed! |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
I'm following this thread with interest.
So managed too get the sc up and running today as well as fitting the paddle kit. Done the supercharger oil change but then I realised I made a bit of a mistake. The car is sitting on a slight incline on the drive way so scrapped that idea after I could only get 30ml of oil out.
