![]() | Home > In Car Electronics (L405) > Incontrol app frozen/not speaking to the car |
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 ![]() ![]() ![]() |
How annoying. I can only think to delete the app, reinstall it and log in again.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 507 ![]() ![]() ![]() |
thanks JM, ive deleted and reinstalled the app with no joy. I'll ring LRA tomorrow. They may be able to help with the SIM not working too. First time FFRR owner |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
I had similar issue, the car was showing parked at the last service station I had visited 50 mile away, and could not get it to work. Next day it was the same.
cheers Kot, I don't have a code reader (yet), surely LRA will be able to assist with any of that. It shouldn't have any issues with battery condition, its had some decent runs (including a 2 hour run today).
Arch
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1631 ![]() ![]() ![]() |
@Kot: |
I love my Range Rover.
Hi Arch:
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1752 ![]() ![]() ![]() |
I've had / am having the same issue.
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Hi comports, it could possibly be faulty telematics control unit. There are a few thing you can do to reset it and see if will reboot. Locate unit ( normally behind n/s c pillar trim) unplug the unit and remove the internal battery. Give it ten minutes and refit it, clear all dtc,s. This might then boot up. Also uninstall and reinstall the app and follow the sos button reset. If after that it still refuses to work May need new unit ( which were and are still possibly on back order) |
Thanks M11
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
the location is in the WM,
Thank you Stan |
Hi, not sure on your reg number to check but found this if helps. ( or not as the case maybe )
