Home > Technical (L405) > SDV8 Motorway Vibrations/Unbalanced Wheel Sensation 70+ MPH
ggm31v
United Kingdom 2017 Range Rover Vogue SE SDV8 Loire Blue
Hi All,
New to the forum, this is my first post!
I took ownership of a 2017 Facelift L405 in October 2022, absolutely love the car, but its always suffered from an annoying vibration/unbalanced wheel symptom on motorways, first of all I got all the wheels checked out and fitted 4x new continental tyres, the wheels aren't buckled (22" turbine)
I even had it to another tyre centre today, who have some super duper balance/diagnostic machine (1 of 3 in the entire country)
The car has full LR history, all diff/transfer/gear box fluids all changed.
Driving around B roads its absolutely fine, its just on motorways at cruising speeds.
I work in the motor trade, and you would swear it was just unbalanced wheels, but its clearly not.
I took it to a local specialist, they said they can feel it! But are stumped as to what it could be - they checked the rear diff fluid and said it looked fresh (replaced back end of 2022)
Any help would be amazing!!
Post #655508 3rd Feb 2023 6:25pm
Phoenix
Check brake temperature after the concern has occurred, also check dampers for leakage, you might have to take them off to do comparative tests. It's not unusual for a damper to suffer from harmonic oscillation at speed with no perceived issues on slower or rougher roads, if you have access to chassis ears, put them on the top mounts of each damper. - can you feel it through the steering or just the body?
Post #655511 3rd Feb 2023 6:56pm
ggm31v
Hi,
It’s mainly the body / the specialist I took it to did hypothesis it could be suspension related, but they didn’t know how to pin point it Sad
Post #655513 3rd Feb 2023 7:09pm
Phoenix
If they don't have 'chassis ears' or know that they are the first line of diagnosis for that sort of concern, I'd suggest somewhere else - doesn't have to be a LR 'specialist', just someone that is more interested and capable.
Post #655515 3rd Feb 2023 7:42pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I agree with the check you road wheel temperatures. I had a similar experience with my old L322 RR that would get the vibes above 50mph. The N/S rear road wheel was hot and the calliper seized.
Post #655602 4th Feb 2023 6:38pm
Killiestu
United Kingdom 2013 Range Rover Autobiography TDV6 Corris Grey
Great advice, i have this exact issue on my 2013 L405. it is going in for a full fluid change shortly so i will get them to look over the brakes when its in. Thumbs Up
Post #656060 8th Feb 2023 5:25pm
ggm31v
Any update on yours? @KillieStu
Post #657298 21st Feb 2023 8:16am
Killiestu
Hi, it looks like I have a rear damper that's knackered causing the wheel to bounce after it goes over bumps and that makes the whole car feel like there is a vibration from that corner.
I had noticed there was a vagueness from the back of the car but I've never owned a RR before so never joined the dots.
Post #657300 21st Feb 2023 8:39am
knwatkins
Do you know how they concluded this Killiestu? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #657369 21st Feb 2023 6:07pm
Killiestu
Yes the local RR garage took it for a drive and the mechanic took a video of the rear wheels as the drove, could see it quite clearly from about 40mph and faster
Post #657370 21st Feb 2023 6:10pm
knwatkins
Good info, thanks Thumbs Up Kev
Post #657371 21st Feb 2023 6:16pm
ggm31v
Is yours a V8? I am lead to believe the V8 has a different damper setup..........
Post #657372 21st Feb 2023 6:29pm
Killiestu
No , 3.0D in mine.
I will be changing the damper this week when it arrives so I will add some photos.
Post #657382 21st Feb 2023 7:07pm
ggm31v
I swapped all 4 wheels, and symptoms still remain.
I am going to take it to Land Rover in Hull, from my experience I suspect its the transfer box...............
Post #658109 28th Feb 2023 6:16pm
Killiestu
Well a quick update from mine.
Changed the damper and done the rear brakes at the same time.
The vagueness is gone but the vibration is still there so getting the wheels checked again for roundness tomorrow morning and if that doesn't solve it I'm hoping the full gearbox and transfer case flush will help
Post #658110 28th Feb 2023 6:24pm
