Home > Technical (L405) > SDV8 Motorway Vibrations/Unbalanced Wheel Sensation 70+ MPH
andycolamax
United Kingdom 2014 Range Rover Vogue SE SDV8 Carpathian Grey
Hi - did you have any joy with vibration. I am experiencing the same issue after having rear disks and pads replaced. Garage is suggesting it’s because tread is the same across all 4 tyres. 3mm front, New rear?
Post #668211 3rd Jul 2023 1:22pm
Killiestu
United Kingdom 2013 Range Rover Autobiography TDV6 Corris Grey
Hi Andy,
Yes my issue was a slightly buckled wheel it was barely noticeable on the wheel balancer machine.
I decided to changed each wheel one at a time with my spare and found one of the rears was at fault.
Managed to pick up a set o genuine RR 21" locally and popped them on.
Post #668223 3rd Jul 2023 3:00pm
Are you running Conti silent tyres ?
If you are, the foam may be deteriorating - https://www.fullfatrr.com/forum/topic49735.html
This thread has some other sufferers but seems inconclusive https://www.fullfatrr.com/forum/topic45733.html
Post #668228 3rd Jul 2023 3:23pm
Stuart-
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
andycolamax wrote:
Hi - did you have any joy with vibration? I am experiencing the same issue after having the rear disks and pads replaced. The garage is suggesting it’s because the tread is the same across all 4 tyres. 3mm front, New rear?
I guess you meant the tread is not the same across the four?
In that case, I'd be tempted to swap two wheels diagonally and see if something changes. If it changes, put the new ones on the front as they wear faster with the steering scrubbing and it might right itself. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #668240 3rd Jul 2023 6:17pm
