![]() | Home > Technical (L405) > SDV8 Motorway Vibrations/Unbalanced Wheel Sensation 70+ MPH |
Check brake temperature after the concern has occurred, also check dampers for leakage, you might have to take them off to do comparative tests. It's not unusual for a damper to suffer from harmonic oscillation at speed with no perceived issues on slower or rougher roads, if you have access to chassis ears, put them on the top mounts of each damper. - can you feel it through the steering or just the body? |
ggm31v Member Since: 03 Feb 2023 Location: York Posts: 7 ![]() ![]() ![]() |
Hi,
If they don't have 'chassis ears' or know that they are the first line of diagnosis for that sort of concern, I'd suggest somewhere else - doesn't have to be a LR 'specialist', just someone that is more interested and capable. |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 142 ![]() ![]() ![]() |
I agree with the check you road wheel temperatures. I had a similar experience with my old L322 RR that would get the vibes above 50mph. The N/S rear road wheel was hot and the calliper seized. |
Killiestu Member Since: 23 Jan 2023 Location: Kilmarnock Posts: 21 ![]() ![]() ![]() |
Great advice, i have this exact issue on my 2013 L405. it is going in for a full fluid change shortly so i will get them to look over the brakes when its in. |
Any update on yours? @KillieStu |
Hi, it looks like I have a rear damper that's knackered causing the wheel to bounce after it goes over bumps and that makes the whole car feel like there is a vibration from that corner.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Do you know how they concluded this Killiestu? Kev
Yes the local RR garage took it for a drive and the mechanic took a video of the rear wheels as the drove, could see it quite clearly from about 40mph and faster |
Good info, thanks |
Is yours a V8? I am lead to believe the V8 has a different damper setup.......... |
No , 3.0D in mine.
I swapped all 4 wheels, and symptoms still remain.
Well a quick update from mine.
