Home > Maintenance & Mods (L322) > Fitting a DPF sensor to my L322 4.4tdv8
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
Question on the above title, has anybody got any video's or links to threads on fitting the DPF sensor?
Thanks in advance!
Post #655333 1st Feb 2023 11:16am
you could have a look at our wiki, download the workshop manual or do a forum search... ... - .- -.
Post #655335 1st Feb 2023 11:33am
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
I tried to fit one on my 4.4 TDV8 and the old one snapped off as I was trying to get it out. Big Cry
Ended up getting a garage to sort it for me. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #655349 1st Feb 2023 3:24pm
kenneally_mark
I downloaded the workshop manual good call. I found it, now to just do the job! Thanks
Post #655353 1st Feb 2023 3:50pm
kenneally_mark
Oh that doesn't sound ideal. I am going to try and tackle mine myself....
Post #655354 1st Feb 2023 3:50pm
DrRob
It’s in the Wiki if it’s P040D code that you’re trying to get rid of on the diagnostic.
Nearside exhaust manifold location. Bitch to get to. I got a specialist to do it who has done hundreds Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #655366 1st Feb 2023 5:37pm
kenneally_mark
It's P244b-68 (28 ) is the code I'm aiming to get rid of.
The other code that came up was U0405-68 (2A)
Post #655368 1st Feb 2023 5:47pm
colalowe
The codes I had were PO42D and PO40D and these were the sensor in the manifold and the sensor between the Cat and the DPF.
Not sure what your codes relate to, hope you manage to sort it though Thumbs Up 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #655425 2nd Feb 2023 1:28pm
kenneally_mark
Thanks man, I will update the thread when I get it done!
Post #655427 2nd Feb 2023 1:57pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I you guys talking about P040D, dont call it DPF sensor. This temperature sensor not related to DPF at all. Its EGR inlet temp. sensor. According readings from this sensor EGR operate the flap inside it, send exhaust gas through heat exchanger or around it (bypass).
Post #655441 2nd Feb 2023 6:45pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
This thread may help, it helped me.
https://www.fullfatrr.com/forum/topic50202-45.html 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #655486 3rd Feb 2023 10:39am
DrRob
Have you looked these up in the DTC folder (with many sub chapters to review) of the Workshop Manual?
It's free via the Wiki page: https://www.fullfatrr.com/wiki/Main_Page
Scroll to bottom
P ones looks to be sensor and the U ones look cruise control module signal related.
You could end up throwing the parts catalogue at it Whistle
I charge nothing for my librarian skills Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #655489 3rd Feb 2023 12:21pm
DrRob
Totally agree. The code the OP has found is not this sensor as you point out Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #655490 3rd Feb 2023 12:23pm
kenneally_mark
Scroll to bottom
DrRob,
Thanks for the links & suggestions. After reading the links I've found out how to reset the reading from the DPF after fitting the sensor!
Post #655895 7th Feb 2023 10:48am
kenneally_mark
So in my simple learnings from fitting this sensor:
1. Buy genuine - I have no intention of fitting another one again or wasting money on doing it twice
2. Make sure you have two clips to replace the ones that feed into the sensor - see attached photo where I've circled it
3. I was wondering how to reset the DPF readings, after DrRob suggested checking the Workshop Manual I found this explanation on how to reset it: NOTE: If a new diesel particulate filter pressure sensor or hose lines have been installed or incorrectly routed, or any pressure sensor circuit repairs carried out, the engine control module must learn and store the new diesel particulate filter pressure sensor offset value. The following conditions must be met to allow the diesel particulate filter pressure sensor offset value to be learnt and stored: Using the manufacturer approved diagnostic system, clear DTCs from engine control module, then monitor the datalogger signal 'sump oil temperature - measured' ensuring a minimum of 50 degrees C is achieved. Start engine, run above 500rpm for 2 minutes, then a further 30 seconds at idle. Ensure the engine cooling fan is not running. Set vehicle in park and set ignition status to off. Wait 30 seconds for the engine control module to power down, learn and store diesel particulate filter pressure sensor offset value. This process must be carried out six times, to allow a large negative offset value to adapt back to 0 Hpa
* Caveat - I'm not a mechanic and nor do I claim to know too much. I'm operating on learnings & advice from this forum etc
Does changing the sensor make a difference: YES!
Post #655896 7th Feb 2023 10:53am
