![]() | Home > Maintenance & Mods (L322) > Fitting a DPF sensor to my L322 4.4tdv8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
you could have a look at our wiki, download the workshop manual or do a forum search... ... - .- -.
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
I tried to fit one on my 4.4 TDV8 and the old one snapped off as I was trying to get it out. |
kenneally_mark Member Since: 09 Jun 2021 Location: Cork Posts: 74 ![]() ![]() ![]() |
I downloaded the workshop manual good call. I found it, now to just do the job! Thanks |
Oh that doesn't sound ideal. I am going to try and tackle mine myself.... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
It’s in the Wiki if it’s P040D code that you’re trying to get rid of on the diagnostic.
It's P244b-68 (28 ) is the code I'm aiming to get rid of.
The codes I had were PO42D and PO40D and these were the sensor in the manifold and the sensor between the Cat and the DPF.
Thanks man, I will update the thread when I get it done! |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
I you guys talking about P040D, dont call it DPF sensor. This temperature sensor not related to DPF at all. Its EGR inlet temp. sensor. According readings from this sensor EGR operate the flap inside it, send exhaust gas through heat exchanger or around it (bypass). |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
This thread may help, it helped me.
Have you looked these up in the DTC folder (with many sub chapters to review) of the Workshop Manual? It's free via the Wiki page: https://www.fullfatrr.com/wiki/Main_Page Scroll to bottom P ones looks to be sensor and the U ones look cruise control module signal related. You could end up throwing the parts catalogue at it ![]() I charge nothing for my librarian skills ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Totally agree. The code the OP has found is not this sensor as you point out ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
DrRob, Thanks for the links & suggestions. After reading the links I've found out how to reset the reading from the DPF after fitting the sensor! |
So in my simple learnings from fitting this sensor:
