Home > In Car Electronics (L405) > L405 Sat Nav repair |
e600 Member Since: 28 Apr 2016 Location: Surrey Posts: 23 |
Sat nav fault identified as gps antenna. The part number is LR 059750. JLR currently out of stock with no know date for supply. A bit of a long shot, has anyone got one spare which of course I would buy.
11th Jan 2023 6:47pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If you're at all handy, you could mount any 5V coaxial GPS antenna in the existing housing - they're reasonably cheap enough to give it a try.
11th Jan 2023 8:54pm |
Many thanks, that’s helpful. I will wait and see what JLR come back with on delivery times and then make a decision on a secondhand unit. |
12th Jan 2023 1:04am |
My satnav now working fine, was the aerial, about £65 from main dealer, easy fit under headlining. Couple of plugs and two nuts with washers and a spreader plate. |
30th Jan 2023 11:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
bit late to this thread but i had DAB problems where in certain areas my signal would drop...this happen always after rain and never when the weather was dry..
31st Jan 2023 7:36am |
Yes, whilst the aerial base has two slimline gaskets I gave both of them a lick of sealant. Should stop any future issues. |
1st Feb 2023 3:30pm |
yelnats6969 Member Since: 17 Aug 2023 Location: kent Posts: 7 |
Did you ever find out what part was replaced or how they fixed it |
14th Feb 2024 11:52pm |
