![]() | Home > In Car Electronics (L405) > L405 Sat Nav repair |
e600 Member Since: 28 Apr 2016 Location: Surrey Posts: 23 ![]() ![]() ![]() |
Sat nav fault identified as gps antenna. The part number is LR 059750. JLR currently out of stock with no know date for supply. A bit of a long shot, has anyone got one spare which of course I would buy.
If you're at all handy, you could mount any 5V coaxial GPS antenna in the existing housing - they're reasonably cheap enough to give it a try.
Many thanks, that’s helpful. I will wait and see what JLR come back with on delivery times and then make a decision on a secondhand unit. |
My satnav now working fine, was the aerial, about £65 from main dealer, easy fit under headlining. Couple of plugs and two nuts with washers and a spreader plate. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
bit late to this thread but i had DAB problems where in certain areas my signal would drop...this happen always after rain and never when the weather was dry..
Yes, whilst the aerial base has two slimline gaskets I gave both of them a lick of sealant. Should stop any future issues. |
yelnats6969 Member Since: 17 Aug 2023 Location: kent Posts: 7 ![]() ![]() |
Did you ever find out what part was replaced or how they fixed it |
