Home > Off Topic - Other Cars > Best double sided tape - fascia trim
pld118
Hi all,
What’s the thoughts on the best make and where to buy it, thinnest, double sided tape for long term sticking down of interior fascia trim?
Thanks
Post #654377 22nd Jan 2023 6:07pm
Phoenix
3M contact sensitive tape - I'll get you a part number tomorrow, it's less than 0.5mm thick so won't cause any bulges.
Post #654381 22nd Jan 2023 7:29pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
I used 3M VHB to repair delaminated caravan windows as a temp repair to get us home, 2 years later it’s still stuck fast so whenever we go caravanning I take a reel or two just in case.
The one I use is 15mm x 1mm and found it on both eBay and Amazon.. Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #654382 22nd Jan 2023 7:30pm
calicoj
Spain
3M VHB tape is likely the best option, but there are many different types depending on what you need it for, what type of materials you're fastening to each other, including the different types of body paint, so don't hesitate to contact your local 3M office and ask for guidance - they're very good at providing advice.
FYI 3M also makes automotive-specific tapes that could do the job too.
I guess my point is this: you can't go wrong with 3M. They're the world leader in adhesives, and by far, for a reason. Just be sure to get the right type of tape for your usage scenario, as professional use tapes can be incredibly specific.
Post #654590 24th Jan 2023 1:35pm
pld118
Thanks very much for the replies.
Where to get the 0.5 mm thick tape, most adverts online seem to be for 1.1mm thick tape…. Does it matter?
Post #654742 25th Jan 2023 10:11pm
Phoenix
Ooops! sorry, forgot - I'll take a photo of it tomorrow.
ETA - seems I did get the part number, 3M 9485, not cheap but available on Zoro, use discount code RET22-1117
Post #654743 25th Jan 2023 10:20pm
calicoj
Spain
It can matter. Tape thickness depends on what you're bonding together and how much space you need in-between. The best thing to do would likely to figure out or ask outright (to a dealer/mechanic) what the correct thickness is so that, in turn, you can buy and use the proper tape/thickness combo.
Thickness can be crucial in some applications but irrelevant for others - it all depends on the desired end-result and the nature and material of said parts.
For instance, some parts need to be as close together as possible for purely aesthetic purposes or to limit ingress of dust, while others may require a small height difference to avoid one part marking the other over time.
Choose wisely and get advice from someone who does this for a living.
Post #654750 26th Jan 2023 6:53am
pld118
Thanks for the replies.
Thinnest thickness tape I could find readily available to buy online was 0.6mm thick:
3M VHB Tape GPH-060GF 19mm width tape x 3 metre length roll
That will be plenty thin enough for the fascia trim it’s needed for here.
Post #655156 30th Jan 2023 4:28pm
UK Marine
👍🏻 it’ll work great. ______________________________
Simon
Post #655179 30th Jan 2023 7:28pm
pld118
Cheers Thumbs Up
Post #655189 30th Jan 2023 7:56pm
