Home > Maintenance & Mods (L322) > Brake Pipes
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Brake Pipes
So, having had my 322 in for £5500 worth of work, within 200 miles the brake pipes went, nothing to do with the work done, called them up to ascertain cost (indy) ' ah yes we know that problem sir, about £2000 ' just had new pipes fitted by local mobile chap for £180, beggars belief Rolling with laughter
Post #655173 30th Jan 2023 7:53pm
mjdronfield
My rear ones were £200 odd I think, especially if you need both flexi hoses doing too.
They made them up as they went, but I know you can get pre made genuine ones but if I remember right, there is more labour to feed those through etc.
Happy to be corrected…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #655181 30th Jan 2023 8:31pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
£2000 Shocked
Gold plated versions ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #655187 30th Jan 2023 8:53pm
pcourtney
the reason is because the main dealers have a habit of breaking the nipples off the Brembo calibers, so they cost in the replacement for brand new calipers - thieving scum
this is all because they cannot be bothered to instruct a junior mechanic on £12 an hour to spray the nipples 5 or 6 times during the day before they attempt to remove the old brake lines ( or leave it overnight to for a good soaking )
the mobile guys know what they are doing most of the time Smile
except when the time comes that they also break the nipples off the calipers Sad
Post #655190 30th Jan 2023 8:57pm
JayGee
To be fair once galvanic corrosion has set in no amount of soaking with plusgas is going to free up the threads. 2012 TDV8 Vogue (L322)
Post #655216 31st Jan 2023 7:08am
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Was just about to post exactly the same point as Rosco, and there this topic is, right at the top of the page!!
Fed up with my local indy (who are so busy, they never seem to have time to look at my car properly), following a brake fluid leak, I sent my L322 with the AA recovery in for a proper health check and repair with my local main dealer.
They have quoted me as follows:
FRONT TO REAR BRAKE LINE HAS RUSTED THROUGH AT FIXING - INSPECTION SHOWS BOTH PIPES RUSTED - REQUIRES BOTH FRONT TO REAR BRAKE LINES AND FULL SYSTEM BLEED CARRIED OUT VIA SDD PROCEDURE
Wait for it....... £2,033.88!
Seems a lot - How much are these pipes, and typically, how much labour is involved in changing them out?
Post #655218 31st Jan 2023 7:41am
Mikey
Have you ever considered that your indy is busy because the main dealer is charging those prices? Whistle Laughing
As far as we are concerned, we are booked solid until early March, with very little wiggle room to accommodate breakdowns etc, and currently have people booking work as far ahead as May Shocked
Post #655225 31st Jan 2023 9:13am
johnboyairey
Making up brake pipes is fairly simple, and costs about a pound a foot. Plus a pound for each union. A flaring tool is all that’s needed to make the flares which complete the new pipe. I’ve made loads up in my time. Often using the old unions if new ones of that size not to hand. So really, you are only paying some for their time to run a bit of string along the old pipe, 5to get the length. then cut a new peice to length from a roll of kunifer pipe… then thread that pipe through the car, next to the old one, bend it around a hard curve, like a large socket… unclip the old, and reclip the new… when it is ready to fit, you can trim the length exact, with a junior hacksaw, drop on the union, flare the end, and fit to the car. It’s advisable to make a blnack ‘dead end’ pipe to hold back the draining fluid, whilst the new is going in, so that the reservoir doesn’t empty and cause airlocks. Especially through the ABS. Bleed brakes, and done.
Post #655226 31st Jan 2023 9:38am
aja500
Thanks John - probably a bit beyond me, sounds straightforward, but if I try it, it will no doubt leak Laughing Laughing
Post #655228 31st Jan 2023 9:43am
aja500
Booked solid until early March...... I'm not sure that's going to work for any customer who needs his car and has no brakes!!
I accept that indy's are busy because they're "cheaper", but with that cheaper price comes this attitude that "we're doing you a favour, and just be grateful we're allowing you to spend money with us".
Personally, I'm at the point where I don't want to hear that anymore - I'd rather pay the extra.
The Main Dealer will be instructed to carry out the work - I'm only asking about the cost of parts and time involved to give me more leverage for negotiating the price down.
Post #655229 31st Jan 2023 9:51am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
When you find a decent Indy for any work on any car you normally have to wait in line!! even then i struggle with some of the labor costs! but i think that is because i can do most jobs just dont have the time!! so have to accept it. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #655230 31st Jan 2023 10:00am
..or you could do it yourself,
https://www.fullfatrr.com/forum/topic25799.html ... - .- -.
Post #655231 31st Jan 2023 10:15am
kevinp
I had my MD do my front to rear pipes with Genuine parts. Yes they will probably rust away again but an health issue stopped me doing them myself.
They quoted for 2.5 hours work, I think, and the total bill was £390 pounds. Parts were £60 anyway.
It in fact took them 8.5 hours so they definitely lost out on this job.
Indies were quoting between £400 and £600.
Part numbers are LR019463 and LR019464.
Post #655233 31st Jan 2023 10:26am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
+1 I followed Joe 90's "how to post" when I replaced all my brake lines with Cunifer.
Post #655244 31st Jan 2023 12:55pm
Mikey
Then it unfortunately has to go elsewhere
We've had to decline 3 jobs this week already, and were only on Tuesday Banging Head
Post #655251 31st Jan 2023 2:12pm
