![]() | Home > Maintenance & Mods (L322) > L322 Reversing lights modification |
Like most, I find the standard reversing lights poor at illumination, mainly as they are inboard rather than at the extents of the vehicle. I've tried LED replacement lamps, pretty underwhelming to be honest - they illuminate the area the camera covers OK but there's barely any spill to the areas you can see in the door mirrors.
Thanks - here's a couple of photos from the back, even off-centre there is a better light output.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
i put 2 boards of 50 which gave me 100 LEDs in mine a lot better also the bottom reflectors were replaced with reverse lights in them as well as turn / and brake .
They look neat, what is the rating of them? - not sure if the reflector replacements would pass an MoT - but I'm not a tester so..... |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
Any chance you’d be able post a link ? TDV8 4.4 2012 |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Yeah there needs to be a red reflector on the back of the vehicle. L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
hi, phoenix not sure about the rating. she went straight through her mot last December the inspector never said anything.
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
Do you have a link to the replacement reflector lights (turn/reverse/Brake) I wouldnt mind a set of them.
hi the item number is ebay eBay Item No. 222932856670 seller r zoro . no vid but I will do one she has been put away for the winter at my workshop to much salt on the roads and I can't power wash still have a hose pipe ban in place . as stated it does need to have the red reflectors some wear on the rear bumper put back in place something else for me to work out and do you can't get away with anything on this site |
Thanks for the AliExpress link @Oggy; much appreciated. TDV8 4.4 2012 |
I got around to modifying the other reversing light, the difference is 'night & day' |
