Home > Maintenance & Mods (L322) > Rough noise from N/S rear
Ragnorak
Just bought a 2011 Range Rover Vogue SE and have one slight issue with it. When driving there is a rough bearing sort of noise coming from the N/S rear wheel. When on throttle the noise appears to go away and is most notable when coasting between 15 and 35mph. The rear discs are worn and corroded so I have ordered up a new set hoping this would be the issue.
Today however I got a handbrake warning fault on the dash. It didn't cause the cracking gear noise as my research leads me to believe this can be a common fault. It just said there was a fault. Turned it off and drove away and the fault cleared. For the time being I am just leaving it in Park...
Question is has anyone else had this, or does anyone know what these symptoms may be? I had thought corroded discs, wheel bearing or CV joint but now with the EPB warning I wonder if they are related...
Thanks for any help...
Post #654856 27th Jan 2023 11:13am
JayGee
The rear callipers are very prone to seizing as well so be prepared to replace or refurb these. The handbrake warning ( flashing) is normal if it's been parked some time and the suspension has adjusted itself as is normal 1/2 hr after shutdown. 2012 TDV8 Vogue (L322)
Post #654862 27th Jan 2023 12:05pm
Ragnorak
Thanks for the response. Had been driving for 30mins before handbrake fault appeared so might not be that... Rear calipers look good but I will investigate further
Post #654864 27th Jan 2023 1:18pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Just to confirm as previously stated. I bought my 2012 in May last year, with corroded rear discs & pads. I had noticed thee before purchase so already had new on order - turns out as well as those the o/s rear caliper was seized and the hand brake shoes had almost totally disintegrated too.. Bonus! Big Cry Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #654872 27th Jan 2023 2:19pm
DrRob
My rear calipers are being renewed next week with Advanced Factors supplied TRW replacements as part of preventative maintenance.
https://www.advancedfactors.co.uk/rear-bra...-175-c.asp
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654881 27th Jan 2023 3:30pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i would do the rear shoes seeing that you are going to remove callipers etc new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #654914 27th Jan 2023 7:58pm
