![]() | Home > Maintenance & Mods (L322) > Rough noise from N/S rear |
The rear callipers are very prone to seizing as well so be prepared to replace or refurb these. The handbrake warning ( flashing) is normal if it's been parked some time and the suspension has adjusted itself as is normal 1/2 hr after shutdown. 2012 TDV8 Vogue (L322) |
Ragnorak Member Since: 27 Jan 2023 Location: Durham Posts: 5 ![]() ![]() ![]() |
Thanks for the response. Had been driving for 30mins before handbrake fault appeared so might not be that... Rear calipers look good but I will investigate further |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 104 ![]() ![]() ![]() |
Just to confirm as previously stated. I bought my 2012 in May last year, with corroded rear discs & pads. I had noticed thee before purchase so already had new on order - turns out as well as those the o/s rear caliper was seized and the hand brake shoes had almost totally disintegrated too.. Bonus! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
My rear calipers are being renewed next week with Advanced Factors supplied TRW replacements as part of preventative maintenance.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
i would do the rear shoes seeing that you are going to remove callipers etc new vehicle purchase
