Home > Maintenance & Mods (L322) > 2012 TDV8 battery drain - I've narrowed it down but... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1201 |
This could be what you are looking for, same fault code, some info on the FFRR thread in the link below, scroll down a bit as the tread has all kinds of work mentioned.
20th Jan 2023 7:32pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
That DTC doesn't mean what you think it means - for a start, the sensor isn't on the 'permanently live' circuit, 'short to ground' means the output of the sensor is at 0V, not the power supply to it.
20th Jan 2023 7:36pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
It’s half way up the radiator on the right hand side from looking at this… towards the bottom of the thread, not the pics near the top
20th Jan 2023 7:40pm |
KristoffL322 Member Since: 20 Jun 2022 Location: North West Posts: 27 |
Thanks very much for the replys guys.
20th Jan 2023 8:58pm |
The 'hedgehog' is the dropping resistor for the HVAC fan, if you have background illumination staying on, then that could well add up to ~3A Use the interior lighting wiring diagram and work back from there concentrating on the circuit(s) you can see are staying on. |
20th Jan 2023 9:07pm |
Thanks, this is what the car looks like even after being locked for 6 hours...
20th Jan 2023 9:21pm |
I don't have the wiring diagrams for your MY to hand - but, it looks to me like there may well be a problem with the lighting control switch, are there any other interior illumination lamps on? vent controls for instance?
20th Jan 2023 10:13pm |
It's dark here now and the car has been locked for over 6 hours so it’s a good time to go and have another look.
20th Jan 2023 10:27pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 370 |
Can you hear the fan running constantly when switched off? The “hedgehog” as described is a common fault that causes a major drain of the battery.
21st Jan 2023 12:24am |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 |
I had the air quality sensor error as you have, and it was a pain to find the location and access is a little fiddly. It is also sometimes referred to as a pollution sensor, which ultimately helped me track down the right part.
21st Jan 2023 7:40am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2515 |
If it gives a clue, mine gets an EPB fault when driven through puddles which keeps the IC alive to show the EPB warning light which flattens the battery overnight if a charger isn't connected.
21st Jan 2023 8:42am |
Hmm... I wonder if there's any moisture in any of the lights or connectors somehow causing the LCM to do something odd - I don't have wiring diagrams for this MY so can't be much help with detective work. |
21st Jan 2023 1:00pm |
I would start with unplugging the top stoplight, hoping that the hazard switch indicator might go off. |
21st Jan 2023 8:56pm |
Thanks for all the replies guys. Significant progress made today (I think).
23rd Jan 2023 2:55pm |
