![]() | Home > Maintenance & Mods (L322) > 2012 TDV8 battery drain - I've narrowed it down but... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
This could be what you are looking for, same fault code, some info on the FFRR thread in the link below, scroll down a bit as the tread has all kinds of work mentioned.
That DTC doesn't mean what you think it means - for a start, the sensor isn't on the 'permanently live' circuit, 'short to ground' means the output of the sensor is at 0V, not the power supply to it.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
It’s half way up the radiator on the right hand side from looking at this… towards the bottom of the thread, not the pics near the top
KristoffL322 Member Since: 20 Jun 2022 Location: North West Posts: 27 ![]() ![]() ![]() |
Thanks very much for the replys guys.
The 'hedgehog' is the dropping resistor for the HVAC fan, if you have background illumination staying on, then that could well add up to ~3A Use the interior lighting wiring diagram and work back from there concentrating on the circuit(s) you can see are staying on. |
Thanks, this is what the car looks like even after being locked for 6 hours...
I don't have the wiring diagrams for your MY to hand - but, it looks to me like there may well be a problem with the lighting control switch, are there any other interior illumination lamps on? vent controls for instance?
It's dark here now and the car has been locked for over 6 hours so it’s a good time to go and have another look.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Can you hear the fan running constantly when switched off? The “hedgehog” as described is a common fault that causes a major drain of the battery.
Davidmudley Member Since: 27 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
I had the air quality sensor error as you have, and it was a pain to find the location and access is a little fiddly. It is also sometimes referred to as a pollution sensor, which ultimately helped me track down the right part.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
If it gives a clue, mine gets an EPB fault when driven through puddles which keeps the IC alive to show the EPB warning light which flattens the battery overnight if a charger isn't connected.
Hmm... I wonder if there's any moisture in any of the lights or connectors somehow causing the LCM to do something odd - I don't have wiring diagrams for this MY so can't be much help with detective work. |
I would start with unplugging the top stoplight, hoping that the hazard switch indicator might go off. |
Thanks for all the replies guys. Significant progress made today (I think).
